The 1971-72 rear axles are "corporate" 8.5" ten bolts, except that they have the bolt-in vs c-clip axles. Any internal parts (gears, bearings, posi) that fit the Chevy 8.5 car axle also fit this. I don't know enough about the truck axles, however, to say they are the same as the car axles.
ALL 8.5 gears are the same.
Will interchange in all 8.5 10 bolt corp. rears.
10 bolt cover 10 bolt ring
Posi units too will also interchange not a problem....BUT you DO NOT WANT a truck auto locker GM limited slip posi unit locker....THEY asre NOT designed for car type playing.
They are low speed operation units 30 MPH and under
over that they do not lock.
So do not bother looking for the TRUCK posi.
You want car unit or aftermarket posi units.
NOW AFTER many years gone by...there are some pick apart trucks that I HAVE SEEN car units in them as guys transferred
over to them and or aftermarket if the stock unit blew up ....SO do open them and check.
THe Auto locker is NOT a bad unit...IT IS just not made for burn outs and fun stuff we all like to do with the cars.
THESE ARE ALL GOOD UNITS IF THEY LOOK LIKE THIS GRAB IT.
