Driveshaft Balancing?
Old Apr 7, 2014 | 04:21 PM
jensenracing77's Avatar
I have never had a driveshaft balanced. Is this something I should have done or is it not needed? I know nothing about the driveshaft for my W-30 build and wondering if i should have it done. It is not twisted and from the best I can tell it is not bent.
Old Apr 7, 2014 | 04:30 PM
It's up to you, in 40 years of working on cars, I've never had to have a stock drive shaft balanced unless I modified it or had it repaired.
Old Apr 7, 2014 | 04:35 PM
archeryshooter's Avatar
Tony
If its not vibrating dont worry about it. If it concerns you have it done
Old Apr 7, 2014 | 05:10 PM
barnfind's Avatar
Tree Row Hunter in N.D.
Done when a custom built driveshaft is made..
Old Apr 8, 2014 | 12:07 AM
rustyroger's Avatar
'87 Delta 88 Royale
If you don't have any driveline vibration your driveshaft is in balance. If it ain't broke, don't fix it .
Roger.
Old Apr 8, 2014 | 02:29 AM
4-Speed's Avatar
Anyone have a lead where to go for a custom built driveshaft and balance?
thanks-
Old Apr 8, 2014 | 02:39 AM
Go to a driveshaft shop. They usually specialize in trucks and heavy equipment.
Let your fingers do the walking.
Old Apr 8, 2014 | 07:56 AM
Run to Rund's Avatar
Even replacing universal joints can throw the shaft out a bit. If it doesn't turn over 300 rpm, not a big deal. If it turns 6000 or better, it is worthwhile to re-balance. There are various performance and race shops who can make and balance a shaft. Two that come to mind and that I have used are Quick Performance and Mark Williams.
Lichtmann
Jun 12, 2014 06:41 PM
miked
Nov 27, 2012 01:38 PM
miked
Nov 14, 2012 08:31 AM
VinMichael
Aug 21, 2012 09:54 PM
csouth
Feb 23, 2010 01:56 PM
