3.91's; Good option for non-race car?
I have 3.91 gears in my 70 442 and while I love the acceleration speed I'm not so crazy about the 3,000 RPM at 60MPH going done the road. I don't drive the car daily but want to be able to go to shows and such more than a few miles from the house.
Anybody had to make this choice before? Did it do what you expected it too?
Fyi
Two options are put a taller tire on the back or install 3.42s into your existing carrier. Swapping in a OD trans is a 3rd option.
What size rear tire do you have on the car now? 3000 rpm @ 60 mph with 3.91 gears indicates that you have a very short 26.3" tall tire on the car.
http://www.discounttire.com/dtcs/infoTireMath.dos
This seems a good calculator that Oldcutlass posted for me when I was weighing options.
And this is the other one,
http://www.angelfire.com/fl/procrastination/rear.html
I also have 3.91's and there a bit steep for the distances we're used to traveling in Texas. If you have a Turbo 400 auto in your car the Gear Vendor overdrive unit is a good choice... a bit pricey but will handle up to 800hp with no worries. As others have posted, taller rear tires, changing the ring & pinion, an overdrive tranny, or a trailer round out your options.
At cruising speeds the transmission gear ratio is 1.00 for th400 and muncie's, is there a significant difference in having an extra gear with muncie 4 speeds vs th400 for highway driving?
4 speed
So for higher gear ratio, ie 3.42, taller tire will maintain lower rpm in higher speed but who wants that...
As stated still 1 to 1 with the rear end ratio once you hit 4th gear.
Over Drive trans built strong is the only way right now with the 12 bolt Olds rear. 700R4 or 200R4 or retro Electronic 4L80 in the rear which are real strong. Might need mid plate to doe this . Jim
It is just RPM's, what does it hurt other than crappy gas mileage? I have A 4-speed car with 3:91 and drive it anywhere I want to go. I admit I don't travel real long distances but wouldn't hesitate too if I really wanted. Your situation may be different living in TX. What distances do you need to travel to attend car shows?
Since your car is a clone I'd consider an overdrive transmission. I've got a 1970 442 that a previous owner swapped a chevy 12 bolt into. It has aftermarket 4.10 gears. In 1995 I found a ZF 6 speed from a 1991 corvette at a reasonable price and with the help of friends modified the Olds bellhousing to fit. There are a lot more overdrive transmissions on the market now so I wouldn't go with the ZF again, but the overdrive made it much more comfortable on the highway. I also got about 17 mpg on the freeway although the quality of gas was likely better back then and may have had something to do with it. The biggest downside was that I had to hack the transmission tunnel much more than I wanted to make the shifter fit. This car was my daily driver through the 1990's. John
My engine is turning 3200-3400 RPM at highway speeds and I drive 35 miles each way to the monthly car club meeting/show and 100 or more miles each way to shows in other cities. The only issue I have is that during the summer with 100+ temps and the AC on the coolant temp gets up to 210 or so. If I slow down and bring the RPM below 3000 the temp comes down to 190 and I can cruise all day.
As others have posted, taller rear tires is a good way to bring down your cruise RPM, if you are really concerned about it. I'm not.
My 72 came with a 2.73 posi. No, it's no off the line sprinter, but it will go all day from 50 to 80 no issue. Downshifting to pass at highway speeds is an absolute joy.
My 67 has 3.08 posi, and I am not planning on changing it. I do more highway driving than drag racing. If I ever do get a drag car, that, of course, is different.
What Size Tires
How far to go?
The good guys nationals in two weeks is only 45 miles from the house but I want to go to the North Texas Olds Club get together in Granbury, TX in April. It's about 2 hours from my house.
With the car being new, just have to get used to it and it needs to prove to me it's reliable. I think any real long distance I'll just trailer and drive locally.
Thanks for the input.
Agreed. That's essentially what I meant by reducing the RPM to below 3000, which would equate to 60 MPH or so. Just hang out in the right lane and wave back at all the folks who will be admiring your ride as they pass by.
Some very good info in the link below addressing optional transmissions and the pros and cons of each vs a true overdrive unit.
http://www.gearvendors.com/
My pleasure. Several of my friends have this unit in a variety of vehicles. To a man, they enthusiastically recommend it and a couple have "tested" the warranty. Excellent product with great customer service is the recurring theme.
The only negative I see is the initial cost. But the quality of the unit and service, combined with the ease of installation and ability to transfer it to another vehicle offset that. Who wouldn't want a W-30, clone or not, with a six speed auto with overdrive?
e.cast728
April 7th, 2014 04:14 AM
Del70
May 18th, 2011 04:10 AM
The Stickman
August 29th, 2009 09:47 AM
