Drive shaft
Old Jun 23, 2023 | 04:06 PM
Chuxter's Avatar
1970 Cutlass Supreme
Drive shaft
Can you powder coat a drive shaft with out affecting the balance?
Old Jun 24, 2023 | 08:46 AM
ART T's Avatar
Not unless it has the rubber damper.
Old Jun 24, 2023 | 10:14 AM
I think you meant "not IF it has the rubber damper". The head from the powder coat oven will likely damage the rubber.
Old Jun 24, 2023 | 03:22 PM
Run to Rund's Avatar
. . .as well as the rubber seals of the universal joints, and cause grease to leak out. If you change the joints, it is a good idea to re-balance the shaft.
Old Jun 24, 2023 | 06:56 PM
I assumed you'd remove the u-joints, since powdercoating requires sandblasting the part first.
kbdecatur
Drivetrain/Differentials
Apr 23, 2023 07:30 AM
442operator
Nov 20, 2022 03:04 PM
johnnyjaws
Sep 4, 2014 12:07 PM
Jay D
Oct 3, 2011 05:28 PM
rose
Feb 24, 2009 10:42 AM
