Differential Question
Old Nov 10, 2009 | 07:25 PM
redvettemike's Avatar
How are the axles in a '71 442 with a posi-traction rear end secured? That is, are they kept in the carrier by 'c' clips or do the bolts out on the end of the axle secure them?
Old Nov 10, 2009 | 07:49 PM
2blu442's Avatar
They're held in by the four bolts/nuts inside the brake pads.
John
Old Nov 11, 2009 | 08:34 AM
John
To expand on that just a little, the retainer plate is held on the axle shaft by a pressed on bearing. Remove the four backing plate bolts, then put the brake drum back over the wheel studs, open side of the drum out. Install three of the lug nuts, flat side towards the drum, so that they engage the threads but allow the drum to slide on the studs. Now use the drum as a slide hammer and the shaft will pop right out. Have a catch pan under the end of the axle tube to catch the drips.
Old Nov 11, 2009 | 07:02 PM
monzaz's Avatar
one more thing
You might want to use a OLD drum as a slide hammer cause I have heard customers complain about this trick and it will bend the drum inner secure if the axles is stubborn. Just another helpful hint so that you do not cause another hidden vibration problem down the road.
Jim
J D Race.com
Wilson
Dec 15, 2011 08:46 PM
MY76GUTLASS
Jan 22, 2011 07:36 PM
jensenracing77
Drivetrain/Differentials
Jul 21, 2010 11:24 AM
rbyers00
May 14, 2010 06:19 AM
nitodog
Nov 30, 2009 07:30 AM
