Diff cover drain plug??
I purchased the perfect launch cover and it has the drain plug in it, I would think you could probably drill a hole and braze weld a nut inside the original and plug it that way. That may work just as well.
http://www.summitracing.com/parts/sum-g1380/overview/
Summit has a number of off the shelf options if your diff has a flat enough spot to install it.
