Conversion to a posi on a '67 Delmont 88
Old Aug 7, 2012 | 05:56 PM
Delmont 88 PA's Avatar
I have a 1967 Delmont 88 with an O-type rear--12 bolts on the cover and, what I'm told, 10 bolts on the gear.
Does anyone know which other B body rear ends would bolt in easily--same spring perches and mounts, etc.?
Right now I'm finishing the engine, body and interior and, to stay married, will probably not be buying a rear until next spring. However, I would like to know which rears would bolt right in and will keep an eye open.
Thanks,
Chris
Old Aug 7, 2012 | 08:49 PM
bdub217's Avatar
Kickin' It Oldschool
There's a site for this conversion and I can't find it anymore (dont remember name), someone knows this though .......Im reading ATM will post back
Old Aug 8, 2012 | 06:24 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Is your Delmont an original 330 or 425 car?
They used different rearends.
A pic would be helpful.
As for swaps, any 65-70 full size Olds will bolt in (but you might need to change the yoke or U-joint and/or driveshaft length).Not positive on other divisions B & C cars.
Depending on which rear it is, it might be easier to swap in a posi differential than find a whole rear.
Old Aug 8, 2012 | 05:26 PM
Thanks for the replies!
It is a 425 car. I would swap it out with a posi differential but they seem hard to find.
Old Aug 9, 2012 | 06:52 AM
monzaz's Avatar
12 bolt olds rears
Ok - There are BIG differences in the A-body to Full size 12 bolt covered OLDS rear
A- body 12 bolt olds has 12 bolt cover (kind of LOOKS like the full size olds 12 bolt cover BUT the full size cover is much bigger in diameter)
A-body 12 bolt olds (found in Cutlass, SX 442 etc.) has 12 bolt cover and 10 bolt ring and pinion.
B-Body FULL SIZE cars 88 98 Etc. will also have the round 12 bolt cover BUT will have 12 bolt RING AND PINION unlike the smallewr A-body 12 bolt cover rear.
A-body ring diameter is 8.4 advertised as 8.5 in all the ordering forms in the aftermarket world and has 3.42 and 3.91 gears available from Richmond Gear.
The B-body 12 bolt rear is 9.3 ring diameter...MUCH larger than the A-body OLDS rear There are NO AFTERMARKET GEARS FOR THIS REAR. PERIOD.
I do have a Posi and 2.93 gears set MATCHED for your car BUT they are not easy to find which makes them much more expensive. PM me I will give you the price. Please be seated when reading it. LOL
Here are the pictures of each.
I KNOW THEY LOOK THE SAME BUT WHEN YOU PUT THEM SIDE BY SIDE THE SIZE DIAMETER IS A BIG DIFFERENCE AND A A-BODT REAR WILL NEVER FIT IN A B-BODY REAR AND VISE VERSA... THE PHYSICAL MOUNTING POINTS ARE NOT EVEN CLOSE.
J D
Jim
Old Aug 9, 2012 | 08:36 AM
oldsmobiledave's Avatar
More info
Donor carrier for the Big 12 bolt is the 1971-1973 Riviera. The Riv came with 3.07 gears as standard issue with optional posi & the Riv GS came with 3.42 gears with posi. Over on the Buick board some years ago there was a push to get 3.73 gears made for this carrier but I do not know how that worked out. At the time I had a 1969 Olds 88 Royale but sold it when I got out of the big cars & lost touch with that forum.
J D
Jim
Delmont 88 PA
Apr 7, 2015 07:04 PM
Delmont 88 PA
Dec 3, 2014 08:01 AM
455 Olds 442
May 31, 2013 06:20 PM
69OldsCutlassS
Drivetrain/Differentials
Sep 9, 2009 01:05 PM
buzzbomb
Jan 6, 2008 09:51 PM
