carrier
Old Feb 7, 2020 | 04:29 PM
442gs's Avatar
carrier
would a 65-66 buick carrier fit my 67 442. thanks Joe
Old Feb 7, 2020 | 06:35 PM
Depends on which axle was in the Buick and what is in the Olds. The 67Olds is likely a Type O. The odds are high that the axle in the Buick is not. Also, WHICH Buick? A-body or full size? The latter definitely won't work.
Old Feb 7, 2020 | 06:49 PM
Oldsmaniac's Avatar
3 of my 67 442's, 4spd cars had the Pontiac 10 bolt cover 8.2 posi rears that were original to my car. These 8.2 Posi rears were also used in the A body Buick. You need to check
Old Feb 7, 2020 | 06:58 PM
442gs's Avatar
1965 gs skylark
Old Feb 7, 2020 | 07:06 PM
442gs's Avatar
no ribs should be good to go . thanks guys
Old Feb 7, 2020 | 07:39 PM
no ribs
??? No ribs does not match any of the available rears for that year.
Old Feb 8, 2020 | 04:37 AM
Oldsmaniac's Avatar
At this point I think not good to go.... more info needed or pictures.
Old Feb 8, 2020 | 06:39 AM
442gs's Avatar
no ribs on back cover
Old Feb 8, 2020 | 07:08 AM
jmos4's Avatar
Hi,
A 8.2 BOP-Buick and Pontiac were internally the same as far as gears and carriers until 67, Buick came out with a redesigned unique to Buick only from 68-70, around 68 Pontiac went to larger ring gear bolts and a largeer bearing on 1 side of the carrier. At least this is what I understand and have read.
65 gs axle (same as wagons except brakes) is unique as has larger axle bearings that you need to get nos, so you might want to put it up for sale, the ring and pinion and carrier should be fine to put in your 67 Pontiac 8.2 axle
Regards,
Old Feb 8, 2020 | 08:40 AM
Did you look at the picture I posted? It takes more than just the back cover to identify the axle. And again, photos would help provide useful info instead of just guessing.
Old Feb 8, 2020 | 06:27 PM
Agreed, the cover could be replaced with a different design so don't use that as an identification method.
Old Feb 9, 2020 | 06:39 PM
monzaz's Avatar
Yes as long as you have a 10 bolt 8.2 Buick to a Pontiac 8.2 ...If you have a 12 bolt cover NO
Plus do not forget that the ring gear must match the series carrier.
lumley69
May 2, 2017 01:59 PM
oldsmobilty
Oct 13, 2016 01:35 PM
lemoldsnut
Dec 20, 2015 09:28 AM
ryneves
Drivetrain/Differentials
Dec 6, 2013 08:20 PM
dynamic88builder
Oct 22, 2005 09:43 PM
