Bearings for the 9.3
yOU NEED TO TELL US THE YEAR OF THE REAR? AND IF IT IS INTEGRAL HOUsing rear 1965-1971 or the earlier gasser 9.3 drop out third member like a 9 ford?
IF it is a 9.3 drop out from 1957 -1964 we need the case casting number to tell you the bearings.
Jim
JD Race
Jim
JD Race
1961 88 as you have for your avatar isCarrier Bearing 25584 X2
Carrier Bearing (Race) 25520 X2
Inner Pinion Bearing 1957-63 M804846
Inner Pinion Race 1957-63 M804810
Outer Pinion Bearing 1957-63 HM89446
Outer Pinion Race 1957-63 HM89410
Pinion Seal 1957-62 19310 SKF
found at:
link - http://www.jdrace.com/content/diff_i...iacDropout.php
Jim
JD Race
found at:
Jim
JD Race
9.3 Olds JD Race vs Fabcraft posi ANTI SPIN
Mine is clutch Eaton style and Fabcraft is Auburn cone unit. My units can be used with 2.69 - 6.14 gears one carrier does everything the shims are on the carrier bearings to move it left and right to make the carrier 2 or 3 series. Mine is rebuild-able down the road - Cone type rear when it is done is junk. NOW how long it takes you to wear one out...??? well you could be dead by then as long as your not circle tracing the car... Jim
Not mine but someone here in Cali is selling these 9.3 pumpkins. It might make sense to pick up a spare.
Pontiac / Olds 9.3 drop out pumpkins
Classiccarjohn
Drivetrain/Differentials
May 18th, 2010 09:49 AM
