Bearings for the 9.3
Old Aug 1, 2022 | 06:24 AM
KQQLCAT's Avatar
Does anyone know what the Timken bearing and race numbers are for the differential are? Carrier and Pinion.
Old Aug 1, 2022 | 09:08 PM
monzaz's Avatar
yOU NEED TO TELL US THE YEAR OF THE REAR? AND IF IT IS INTEGRAL HOUsing rear 1965-1971 or the earlier gasser 9.3 drop out third member like a 9 ford?
IF it is a 9.3 drop out from 1957 -1964 we need the case casting number to tell you the bearings.
Jim
JD Race
Old Aug 1, 2022 | 09:12 PM
monzaz's Avatar
9.3 gm rear end pics for id
these are the 2 you could have 9.3 rear GM
Old Aug 1, 2022 | 09:16 PM
monzaz's Avatar
1961 88 as you have for your avatar isCarrier Bearing 25584 X2
Carrier Bearing (Race) 25520 X2
Inner Pinion Bearing 1957-63 M804846
Inner Pinion Race 1957-63 M804810
Outer Pinion Bearing 1957-63 HM89446
Outer Pinion Race 1957-63 HM89410
Pinion Seal 1957-62 19310 SKF
found at:
link - http://www.jdrace.com/content/diff_i...iacDropout.php
Jim
JD Race
Old Aug 1, 2022 | 09:17 PM
monzaz's Avatar
the other integral housing is linked below too.
http://www.jdrace.com/content/diff_id/12b93Olds.php
Old Aug 2, 2022 | 05:21 AM
KQQLCAT's Avatar
I just bought a rear out of a 62 Starfire 3:42 gears and want to put a posi in it. The third member looks just like the picture.
Thanks for the info
Old Aug 3, 2022 | 05:17 AM
KQQLCAT's Avatar
Do you sell posi units?
Old Aug 3, 2022 | 06:53 AM
monzaz's Avatar
Yes, I sell Eaton posi and bearing kits the gears still come from FAB CRAFT they have a corner on the market...
Jim Mitschke
JD race
Old Aug 3, 2022 | 10:25 AM
KQQLCAT's Avatar
Whats the difference between your posi and fabcraft?
Old Aug 3, 2022 | 04:46 PM
monzaz's Avatar
9.3 Olds JD Race vs Fabcraft posi ANTI SPIN
Mine is clutch Eaton style and Fabcraft is Auburn cone unit. My units can be used with 2.69 - 6.14 gears one carrier does everything the shims are on the carrier bearings to move it left and right to make the carrier 2 or 3 series. Mine is rebuild-able down the road - Cone type rear when it is done is junk. NOW how long it takes you to wear one out...??? well you could be dead by then as long as your not circle tracing the car... Jim
Old Aug 4, 2022 | 05:01 PM
v8al's Avatar
Registered Olds Owner
Not mine but someone here in Cali is selling these 9.3 pumpkins. It might make sense to pick up a spare.
Pontiac / Olds 9.3 drop out pumpkins
Old Sep 6, 2022 | 10:22 AM
monzaz's Avatar
I wish I was on that side of the country with a 14 foot panel truck for a month...lol
Old Sep 18, 2022 | 07:24 AM
KQQLCAT's Avatar
I got the POSI installed boy what a difference the 3.42s make.
Thanks MONZAZ
Old Sep 19, 2022 | 06:39 PM
monzaz's Avatar
What did you go from? if it was 2.xx ratio......... YAH it should feel like a bullet out of the hole now.
Old Sep 21, 2022 | 12:02 PM
KQQLCAT's Avatar
I had 2.87 gears before
Old Sep 21, 2022 | 12:34 PM
OLDSter Ralph's Avatar
Now you need some BIG rear tires ! ! !
airborne1942
Drivetrain/Differentials
Sep 19, 2022 10:08 AM
Sid
Nov 10, 2014 07:40 AM
foo
Jan 27, 2013 04:48 PM
Doug in SD
Jul 8, 2011 06:58 AM
Classiccarjohn
May 18, 2010 09:49 AM
