axle bearing retainer
I was wondering where I could find axle bearing kits, for a 70 Cutlass with a 12 bolt rear end? I can probably get the bearings by cross referencing the nos. and I think I can get the seals, but I don't know where to get the "retainer." Anybody know?
Hmm, seems I had the same conversation with the guy behind the parts counter.There is NO clip.You are perhaps thinking of a Chevy or Ford rearend.The original retainer is a pressed metal affair, removed by careful use of a chisel.You then replace it with a solid metal "retainer." If anyone knows where I can get one, please post.
Are you talking about the metal collar that goes on the axel shaft after the bearing? If so, the last several sets of bearings I've bought had the collar/retainer included with the bearing.
Don
Don
axle bearing retaining collar
Bunser, I have this same problem and i build diffs...lol. You can not buy them seperately. you ahve to buy the whole bearing set to get that collar. Well at least I have not found anyone yet that sells them. SO if you find a supplier please let me know...lol.
That is your answer...you have to buy the whole SetA9 bearing or RW507CR sealed bearing. crummy huh.
Good luck , Jim
jdrace.com
Good luck , Jim
jdrace.com
I was able to get bearings,collar and seals from Supercars Unlimited. (www.supercarsunlimited.com) ORDERS (only) 1-888-OLDS442
Phone (503) 641-1442
They seem to know their stuff! Would recommend them.
ps
Bearings and collar came as a set...wouldn't sell separately.
ps
muscle car resto
Drivetrain/Differentials
May 26th, 2015 07:44 PM
62 Olds
March 24th, 2015 06:51 PM
Flye
July 30th, 2009 10:24 AM
