A9 wheel Bearing - Which side of bearing is toward retainer?
Old Jul 27, 2009 | 04:52 PM
Flye's Avatar
8.5 bolt in Axle-71 Olds
A9 Bearing, wheel/axle bearing.
It definitely is NOT symetrical from a top view. It bulges slightly more on one side than the other. It has an extra 'band' on one side, and is 'open' on the other. There has to be a side that goes in first that is against the retainer, and the other side, obviously faces out toward retainer/wheel. See Pics.
My question is:
"Which way does it install?"
Old Jul 27, 2009 | 05:14 PM
OLDSRALLYE350's Avatar
The middle picture is how the bearing should look when going into the rear end housing. The bearing pushes into the race or outside ring in the picture.
Old Jul 27, 2009 | 05:20 PM
Flye's Avatar
Thanks. Can I get clarification? It is pressed onto the axle, but I'm not sure what 'pushes into the race or outside ring in picture' means.
Thanks again.
Old Jul 27, 2009 | 05:32 PM
Yes its pressed onto the axle when you hold the bearing in your hands and push the inner part you can feel it pressing into the outer ring turn it around and it pushes apart or away from the outer ring.
Old Jul 29, 2009 | 08:20 PM
monzaz's Avatar
a9 install direction help
Here is a helpful picture I hope...lol
Green is the housing
red is the retaining plate blue is the seal
The bearing is correct in the housing - just do it like the picture. Jim
Old Jul 30, 2009 | 10:24 AM
Flye's Avatar
thanks, perfect!!!!
Since I put it in last night, glad I guessed right....
actually the press guy guessed right would be more correct.
muscle car resto
Drivetrain/Differentials
May 26, 2015 07:44 PM
62 Olds
Mar 24, 2015 06:51 PM
mbrae5
Sep 5, 2012 04:15 AM
j_link
Aug 20, 2011 10:01 AM
Bunser
Apr 21, 2008 03:12 AM
