72 442 Rear Differential ID
Hi,
I have a 72 442 that I am trying to make sure the differential is correct. Base on the window sticker it should be a posi 2.73, it is a posi but I can't find the ID number were they are suposed to be on the right tube. The only numbers I could find is on the housing and they are 407296 on the frt right side of the housing and a CE on the lefts side. Does anybody know if these numbers are correct? My 442 was built in 12/71.
Thanks,
Thanks,
These numbers can be very faint after all this time. Use a wire brush to knock off some dirt and see if the numbers are there.
Also, I think all posis had a tag held on by one of the diff cover bolts that said to use special oil. It the tag there?
Window sticker? You have the window sticker? Very cool! Tell us about the car, and pictures are required here.......otherwise, we won't talk to you! (jk)
There is no way to tell for posi sure (like that pun?) if the rear is original. To verify that he housing has the same ratio code as the window sticker, you should be looking on the back side of the passenger side axle tube about 8" from the differential case. The letters are stamped and they are about 1/4" high. That location is approximate and often the stampings are upside down.
Thank You, Awesome Plate. I am restoring a 72 442 U code convertible. I have the window sticker and protecto plate. I am still looking for the build sheet, it also has a W25 hood which was a $154 option on the window sticker. This is a great website and I appreciate all the help so far. Thanks again.
the only place i know of a CE code is 73 and 74. CE is an anti spin. i can't be sure that my info is correct. 3:23 gears.
Last edited by jensenracing77; February 6th, 2009 at 04:25 PM. Reason: i had the year of the car wrong
monzaz
March 20th, 2009 02:28 PM
monzaz
March 15th, 2009 04:43 PM
