72 442 Rear Differential ID
Old Feb 1, 2009 | 08:13 PM
KZ442's Avatar
Hi,
I have a 72 442 that I am trying to make sure the differential is correct. Base on the window sticker it should be a posi 2.73, it is a posi but I can't find the ID number were they are suposed to be on the right tube. The only numbers I could find is on the housing and they are 407296 on the frt right side of the housing and a CE on the lefts side. Does anybody know if these numbers are correct? My 442 was built in 12/71.
Thanks,
Old Feb 1, 2009 | 10:41 PM
old98owner's Avatar
These numbers can be very faint after all this time. Use a wire brush to knock off some dirt and see if the numbers are there.
Also, I think all posis had a tag held on by one of the diff cover bolts that said to use special oil. It the tag there?
Old Feb 2, 2009 | 06:01 AM
Oldsguy's Avatar
Past Administrator
Welcome to both of you guys. I agree that there should be a tag on the differential cover.
Old Feb 2, 2009 | 09:41 AM
KZ442's Avatar
Diff ID
Thanks, there is a tag there and I know it is a posi, I just want to verify it is original to the vehicle.
Old Feb 2, 2009 | 10:53 AM
wmachine's Avatar
Trying to remember member
Window sticker? You have the window sticker? Very cool! Tell us about the car, and pictures are required here.......otherwise, we won't talk to you! (jk)
There is no way to tell for posi sure (like that pun?) if the rear is original. To verify that he housing has the same ratio code as the window sticker, you should be looking on the back side of the passenger side axle tube about 8" from the differential case. The letters are stamped and they are about 1/4" high. That location is approximate and often the stampings are upside down.
Old Feb 2, 2009 | 11:06 AM
wmachine's Avatar
And by the way, both my '66 and my '69 442s have the license plates "KZ 442".
Old Feb 2, 2009 | 09:29 PM
KZ442's Avatar
Thank You, Awesome Plate. I am restoring a 72 442 U code convertible. I have the window sticker and protecto plate. I am still looking for the build sheet, it also has a W25 hood which was a $154 option on the window sticker. This is a great website and I appreciate all the help so far. Thanks again.
Old Feb 6, 2009 | 04:22 PM
jensenracing77's Avatar
the only place i know of a CE code is 73 and 74. CE is an anti spin. i can't be sure that my info is correct. 3:23 gears.
Last edited by jensenracing77; Feb 6, 2009 at 04:25 PM. Reason: i had the year of the car wrong
Old Feb 6, 2009 | 07:14 PM
wmachine's Avatar
KZ, is that CE on the axle tube or the differential housing casting?
Old Feb 6, 2009 | 09:55 PM
KZ442's Avatar
Hi,
The CE is on the left side of the diff housing casting not the axle tubes.
Thanks,
Old Feb 7, 2009 | 10:45 AM
wmachine's Avatar
Okay, you should find the axle code on the tube as I mentioned above.
Old Feb 8, 2009 | 07:53 AM
KZ442's Avatar
Hi Wmachine,
Thanks for your help I found it.
scrappie
Drivetrain/Differentials
Jul 18, 2009 06:19 PM
monzaz
Mar 20, 2009 02:28 PM
monzaz
Mar 15, 2009 04:43 PM
KZ442
Feb 15, 2009 06:59 AM
66starfire
20
Feb 2, 2007 01:26 PM
