71-81 trans am rear end in 1971 cutlass?
Old Dec 28, 2013 | 06:17 AM
71cutlass350's Avatar
Hi, I'm looking to put some lower gears in my 1971 cutlass with the GM corporate 10 bolt and it's cheaper to buy a whole axle than to swap the gears. So I have found several axles from trans ams, would they bolt right in I heard it's the same corporate 10 bolt? Thanks
Old Dec 28, 2013 | 06:40 AM
dmullin's Avatar
azure blue 442
Keep in mind that the t/a Camaro rear end has leaf spring mounts not coil and control arm like your car, but the carrier and gears may work.
Someone on here will know about axle length.
Old Dec 28, 2013 | 07:19 AM
As noted, the 1970-81 F-body used a leaf spring rear suspension. There are no provisions on the housing to attach the control arms or coil springs for the Cutlass rear suspension. Only the carrier and gears are usable.
Old Dec 28, 2013 | 08:39 AM
oldsmobiledave's Avatar
More
And the cover.
Old Dec 28, 2013 | 12:48 PM
Ok I was under the misconception that it was the whole housing would exchange but its probably just the internals. What other cars could I look at to get a axle that would bolt in?
Old Dec 28, 2013 | 05:10 PM
Fyi
Start with 1968-72 GM A bodies.
Old Dec 30, 2013 | 06:40 AM
monzaz's Avatar
rear swap
You have a very desirable rear being the 10 bolt 8.5 was only in 2 years 1971 1972. JUST tighten the belt spend the money on the GOOD 71 72 10 bolt 8.5 rear.
ALL other 10 bolt and 12 bolts in the 1965-1972 era will require you to do drive shaft mods.
Jim
JD
Old Jan 19, 2014 | 10:08 AM
1984 Hurst Olds's Avatar
Is your 8.5 10 Bolt a Posi?
Old Jan 19, 2014 | 03:44 PM
No it is not
Old Jan 20, 2014 | 06:14 PM
monzaz's Avatar
camaro rears
The guts from the Camaro will bolt into your housing NOT the complete axle assemble housing. Axle shafts are also NOT compatible .
Jim
JD
monzaz
Oct 26, 2020 07:05 PM
350TurBRO
Sep 12, 2014 11:52 AM
Zemanek889
Jul 14, 2012 05:02 PM
Draven
Aug 20, 2009 02:07 PM
2blu442
Mar 21, 2009 04:16 PM
