7.5 rear rebuild
Old Dec 29, 2019 | 11:43 AM
Reese Jacobs's Avatar
7.5 rear rebuild
After serious considerations of many options, ive decided it would be most fun/challenging/gratifying to rebuild my 7.5 rear in my 83' Delta for the purpose of putting lower gears (Dorman brand 3.23) to replace the stock 2.41s.
This car is just my DD that I would like to take into the next decade but also not limp down the road without 4 barrels.
The current setup has ~95k on it. Could I use the stock diff w/ 3.23s and save some coin
or
is it worth it to buy a new/used limited-slip or posi for a DD. I just dont want the build to nickel and dime me.
opinions welcome
Old Dec 30, 2019 | 06:01 AM
brownbomber77's Avatar
Just throwing it out there, but the rear axle from 77-96 B-Bodies will all interchange with your car. May want to consider finding a used 8.5" (stronger) B-body rear before venturing into this. I understand you have the 7.5" which means you probably have 4.75"x5 bolt pattern. A new set of axles can address that or a drill guide. For what it's worth, I do have an 8.5" 3.23 open disc brake rear for a B-body ready to bolt in with both bolt patterns drilled. BUT, 2.41 to 3.23 will wake the car up a LOT. My neighbor has an '84 Caprice with a 305 and had 2.73 gears. It can actually do a real burnout now and moves around the city a lot better with the 3.23.
Old Dec 30, 2019 | 06:56 AM
Yeah, I will agree that the rebuild is a tall order, especially after discovering this morning that I would need a new carrier. Out of curiosity, what are you looking to get for that rear you've got.
Old Dec 30, 2019 | 09:47 AM
Hammerdrop's Avatar
I have a 1993 axle but also with the 5 x5 bolt pattern, drums and a 3.42 open. Near Chicago. Axles would need drilling for 4.75 and machining the center smaller. $100. Cheers.
Old Dec 30, 2019 | 10:04 AM
I'm confused by what you mean by this....
Old Dec 30, 2019 | 12:01 PM
Hammerdrop's Avatar
I think your wheels have a 2 3/4" center hole and the larger 5" bolt pattern uses a 3" center hole. Therefore the axles would have to put on a lathe and machined down to 2 3/4".
I think any machine shop can do this and also drill a set of lug holes on a 4 3/4" circle.
Old Dec 30, 2019 | 04:57 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The best choice is a used gear set and carrier from a S10 or Astro Van. Most 80's Astro Vans came with 3.23 open carriers, just needs to be 1989 or older to make sure it is the 26 spline axles rear. My wrecker checked 8 or 9 Astro Vans to find my 3.42 gears, most were 3.23 from what he said.
Old Dec 30, 2019 | 07:32 PM
svnt442's Avatar
Most S10 4x4 pickups came with 3.42 gears as well. If you find a ZR5 those should be 3.73 gears.
But...I liked the 3.23 gears with the 3 speed trans. I installed them in my 80 cutlass up from a 2.28. You wanna talk night and day difference....lol. I got the posi carrier and gears from a mid 80's Camaro. YMMV.
Old Dec 30, 2019 | 08:45 PM
Music to my ears. My dad recently bought an 85' Astro that he has already planned on changing out the [now known] 7.5, so he has got me covered on that now.
My first thought would be to just swap everything over while maintaining shim locations for a good start on pinion depth and bearing preload and just keep old races. Do you think it'd be close enough for comfort to use delta pinion races with the bearings from astro?
Old Dec 31, 2019 | 06:52 AM
Hammerdrop's Avatar
[QUOTE
But...I liked the 3.23 gears with the 3 speed trans. I installed them in my 80 cutlass up from a 2.28. QUOTE]
I also think getting rid of that horrible 2.41 should be your first modification contrary to what some think. My Custom Cruiser with a 3.23 is at least a bit snappier than others with those lame standard ratios.
Old Sep 10, 2020 | 04:02 AM
Redog's Avatar
If you are going to build the 7.5 rear axle, please do not use Dorman parts.
Cheap and will fail
Old Sep 10, 2020 | 08:55 PM
Cheap and will fail
Yes thank you. I opted to go for a set of used GM 3.42 ring & pinion off Monzaz page on ebay.
Also found myself a nice NOS series 3 open carrier to put them in.
I just havent taken the time to open up the diff yet as I don't wanna put more on my plate at the moment.
Kyle's77cutlass
Drivetrain/Differentials
Dec 29, 2019 07:07 AM
deadeyejedi
Oct 21, 2018 05:25 PM
Olds1971
Jun 12, 2014 02:33 PM
Fummins
Apr 18, 2012 04:52 PM
Redog
Feb 9, 2009 01:13 PM
