69 Stock Rear End-- what can it take?
I'm pushing about 600-625 ft lbs of torque on my engine build.
I am curious if you all would be fine running this with a 1969 442 rear end.
8.5" Olds 12 bolt, 3.23 gears, 28 spline
I'm open to upgrading components or is it better to switch over to a Chevy 12 bolt.
Every manual transmission (M-21 close ratio) or rear differential I broke was on the starting line at a dragstrip, 3,500 RPM's or higher with drag slicks. If you are running a wide ratio M-20 with street tires, you should be fine.
.......Just my two cents worth. ..
My worthless two cents...
Use a Ford 9 inch. Its not a shame to do so. Drag racers use 'em all the time. Heck, put a fake 12 bolt 'cover' over the back of it and most folks will never know its a Ford rear end.
I installed a 12 bolt in mine after the restoration. I have 4.10 gears, Tremec TKX and 575 HP with 600 torque. Love it.
jmac69cutty's
Drivetrain/Differentials
March 17th, 2009 05:11 PM
