69 Stock Rear End-- what can it take?
Old Oct 1, 2024 | 03:02 PM
MPSax's Avatar
I'm pushing about 600-625 ft lbs of torque on my engine build.
I am curious if you all would be fine running this with a 1969 442 rear end.
8.5" Olds 12 bolt, 3.23 gears, 28 spline
I'm open to upgrading components or is it better to switch over to a Chevy 12 bolt.
Old Oct 1, 2024 | 04:06 PM
I recall a factory 1970 W-30 4 speed car broke the original 3.91 carrier at the drag strip using sticky tires. Installed a Chevy 12 bolt with 3.90 gears and didn't have issues.
Old Oct 2, 2024 | 11:12 AM
OLDSter Ralph's Avatar
If you have 600-625 ft. lbs. of torque, you aren't running a "G block" 400. It isn't "torque" that kills a rear end. Its the sudden application of power to a stationary automobile..."sudden dumping the clutch" with sticky tires that "bite" at 3.000 RPM's and higher.
Every manual transmission (M-21 close ratio) or rear differential I broke was on the starting line at a dragstrip, 3,500 RPM's or higher with drag slicks. If you are running a wide ratio M-20 with street tires, you should be fine.
.......Just my two cents worth. ..
Old Oct 2, 2024 | 11:23 AM
If you switch to a Chevy 12-bolt, you'll probably want to eliminate the C-clips.
Old Oct 2, 2024 | 11:27 AM
Just out of curiosity, what engine is this build based on?
Old Oct 3, 2024 | 07:21 PM
crossboss's Avatar
Past owned:
My worthless two cents...
Use a Ford 9 inch. Its not a shame to do so. Drag racers use 'em all the time. Heck, put a fake 12 bolt 'cover' over the back of it and most folks will never know its a Ford rear end.
Old Oct 3, 2024 | 07:32 PM
442Dude's Avatar
I installed a 12 bolt in mine after the restoration. I have 4.10 gears, Tremec TKX and 575 HP with 600 torque. Love it.
Old Oct 4, 2024 | 08:36 AM
Given the differing structures of the two units, I'm wondering how this would be done. Have you seen it before?
Old Oct 5, 2024 | 01:14 PM
MPSax's Avatar
Correct- this will not be my G-block. It runs very strong, but not quite enough for my taste. It will be re-sealed, painted and sit in a bag in the garage.
I am building what will be about a 480ci stroker.
I am leaning on seeing how it goes-- being careful not to hook up. Having the original 15' skinny BFGs, already spin with the G block, so I think it might be OK-- just a smoke show until I have the money set aside for something else.
I do like the idea of a Ford 9inch- the made-ready kits from Moser might be the ticket.
Old Oct 5, 2024 | 01:15 PM
MPSax's Avatar
Thanks Ralph-- I'll be using a TH400
Old Oct 5, 2024 | 10:35 PM
Then you have nothing to worry about. If you do happen to twist an axle, you can replace it with a Moser or Dutchman axle. I think you are worrying about something that doesn't need a solution.
Old Oct 6, 2024 | 05:13 AM
MPSax's Avatar
thanks- just wanted to make sure. Appreciate all the input!
camshaw
Dec 8, 2013 05:40 PM
Fummins
Drivetrain/Differentials
Sep 19, 2013 08:11 PM
mmurphy77
Feb 1, 2013 11:25 AM
michael hilsabeck
Nov 5, 2011 08:27 AM
jmac69cutty's
Mar 17, 2009 05:11 PM
