'68 442 Convertible Rear Dif
Old Jan 17, 2023 | 12:52 PM
Pigs Fly Garage's Avatar
5th Grade Dreaming
Hey Olds masters,
I have this type "O" rear differential currently. I don't know gearing, but it is an open dif.. After getting it all clean and shiny, the shaft seal is leaking. I don't mind fixing, but I am wondering if anyone has thoughts on donor cars with GM rear difs with a posi and cruising gears?
I would like to stay in the 1968-72 range.
I would like a posi type.
I will mainly be cruising and "occasionally" melting rubber.
Any advice on gear kits with posi that might bolt up right for the current setup instead a whole new rear axle assembly?
1968 Oldsmobile 442 Convertible with 455 and TH375.
Old Jan 17, 2023 | 02:34 PM
1970 Cutlass 3:08 posi rearend - ClassicOldsmobile.com
Old Jan 17, 2023 | 03:41 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yeah, that new Yukon posi is 3/4 the price of that rebuilt Type O, trust me🤑🤑🤑. I am doing that exact set up this Summer to replace my 2.78 open, just need the bearings and seals.
Old Jan 17, 2023 | 03:51 PM
Bob Kelso's Avatar
Some Cutlasses that were built in Canada came with the Chevy 12 bolt rearend , you can get every thing you need to build the 12 bolt Chevy that you have from the after market vendors ,
Old Jan 17, 2023 | 04:22 PM
No, you don't. The O-Type has a 12 bolt cover, which is not what your picture shows. That is obviously a 10 bolt rearend, maybe a 71-72 8.5" 10 bolt or maybe an 8.2" 10 bolt. Need some views of the side of the center section and/or casting numbers for better identification.
Both of the above 10 bolt rears have a lot of aftermarket parts available; you just need to determine exactly which one it is.
Old Jan 25, 2023 | 12:12 PM
5th Grade Dreaming
Name that rear end
Appreciate the info. Here is what I have found:
Axle tube is stamped "CB" "226W"
My conclusion...from the manual:
Likely geared 3.36
Made Feb 26 in Warren, MI
I am guessing an 8.5? I need to replace the pinuon shaft seal and need to determine which seal to purchase. Does it matter which type housing 8.2 or 8.5, or are all pinion shaft seals the same flavor?
Any help is appreciated.
Old Jan 25, 2023 | 12:44 PM
Look for casting numbers on the center section - those will identify what it is.
Here's a picture I found on the web showing one possible casting number location:
https://www.chevydiy.com/history-and...differentials/
The placement of the casting numbers on an 8.2-inch 10-bolt varies
by year and model. When you decode these numbers you can
conclusively identify your axle.
Old Jan 25, 2023 | 01:12 PM
Old Jan 25, 2023 | 01:51 PM
5th Grade Dreaming
What the what?
So,
Type "o" cover. Type "o" parallel vanes on the side of housing. "CB" stamped on the axle tube.
I have no cast "lugs" on the housing at 5 and 7.
I am pretty certain I have an 8.2 w/ 3.36:1 gears made in Warren, MI.
Have I named that rear end?
I WAS HOPING FOR AN 8.5 I COULD BUILD! Oh well, what's another 2k?
Seems like I'll grab an 8.5 from a parts donor location. Keeping my eye out for a 12 bolt posi...hahaha.
Appreciate the help holding my hand through this identification process. You all are awesome.
Old Jan 25, 2023 | 01:54 PM
So,
Type "o" cover.
Sorry if I'm confused, but are you talking about the axle in your first photo? That's clearly not a "Type O cover", since it has the inverted "V" notch and only ten bolts.
Old Jan 25, 2023 | 02:00 PM
5th Grade Dreaming
Damn old eyes
You are clearly correct. Thank you for clarifying. My apologies.
Old Jan 26, 2023 | 03:48 PM
5th Grade Dreaming
Translation verification?
GM51 w/ a smaller "O" stamped above the GM51
Old Jan 26, 2023 | 03:55 PM
It's still a Chevy 8.2" ten bolt axle from a Chevelle. It wasn't born under that car.
Old Jan 26, 2023 | 03:59 PM
5th Grade Dreaming
Appreciate ya.
Really appreciate the help.
Old Jan 26, 2023 | 04:07 PM
v8al's Avatar
Registered Olds Owner
Pretty sure you have a GM/Chevy 8.2
Old Jan 26, 2023 | 04:12 PM
5th Grade Dreaming
Its so crazy how sometimes I sometimes am convinced something is this or that, and the real answer is literally RIGHT IN FRONT OF YOUR FACE!
Old Jan 27, 2023 | 04:37 AM
allyolds68's Avatar
If you have an Oshawa built car it's probably the original rear. Why not just put a posi in it? I would think there are more options for that rear than a type O. I have a 3.42 with an M20 and I think it's a good match. I don't know anything about automatics though
Old Jan 27, 2023 | 04:55 AM
Sorry, no. Oshawa cars got the Chevy TWELVE bolt axle with the 8.875" ring gear, not the 8.2" ten bolt.
Old Jan 27, 2023 | 05:30 AM
allyolds68's Avatar
Got it. Thanks
A quick google search implies (because I admittingly don't know) that an 8.2 posi is fairly easy to obtain and most people will never need the strength of a 8.5 or 8.875 for their daily driver
Old Jan 27, 2023 | 07:44 AM
To clarify, Canadian (Oshawa) built cars came with the Chevy 12-bolt in '68-9. US cars got the Type O. Available ratios differed between the two; my understanding is that the 12-bolts were commonly equipped with a 3.07 and the O's with a 2.73 or 3.08. In either case Posi (Anti-Spin) was optional.
Old Jan 27, 2023 | 07:47 AM
The standard and available axle ratios are listed in the SPECS booklets and differed between the two axle types. In any case, this is not relevant to the OP's non-original Chevy 10-bolt that is the subject of this thread.
Old Jan 27, 2023 | 09:00 AM
v8al's Avatar
FYI - How to Rebuild Chevy/GM Differentials 10 and 12 Bolt
It's also available on Hoopla. Depending on your local library system, you can sometimes get free access to Hoopla through your library account.
Old Jan 27, 2023 | 10:12 AM
Comes under the heading of info that might be useful if OP is still up in the air about replacing his current unit, as he appears to be. Good referral to the Specs book!
my68
Sep 14, 2022 09:47 AM
ben442
Drivetrain/Differentials
Jun 1, 2018 08:59 PM
Big Features
May 31, 2016 08:25 PM
diablo76delta88
May 24, 2004 04:47 PM
