71 Cutlass Supreme rear end
Old Jan 28, 2023 | 07:39 AM
tjfritz's Avatar
I have a 71 Cutlass Supreme convertible that originally had a 350ci with a Muncie 4 speed that has been in the family almost 40yrs. A couple yrs ago I swapped out the 350 for a 455 and now want to change the rear gears and go posi. It is a 10 bolt cover but I cannot tell if it's a BOP or GM and doubt seriously the rear housing etc has been changed. I have spoken to Eaton, Summit & Jegs and am now more confussed. Before I buy a posi and new gears I would like to know definitely.
Thanks, Ted
Old Jan 28, 2023 | 07:45 AM
You have the Oldsmobile version of the "corporate" 8.5 inch ten bolt axle, which was used in every 1971-72 Olds A-body that left the factory. The center section (gears, differential, bearings) are the same as those on every Chevy 8.5 inch ten bolt axle. The biggest difference is that the Olds version uses bolt-in axle shafts instead of the Chevy C-clips. This has no effect on the use of the Chevy posi units or gears in this housing.
Old Jan 28, 2023 | 08:08 AM
tjfritz's Avatar
Thanks for the quick reply Joe. I have attached a page from Eaton on passenger car differentials and highlighted the two possibilities, which is the correct one for my car?
19674-010 or 19603-010
Thanks, Ted
Old Jan 28, 2023 | 08:40 AM
Thanks, Ted
Neither one. One more time, this is an 8.5 inch ten bolt axle, not the 8.2. Ignore the "c-clip" reference.
As I said above:
Old Jan 28, 2023 | 09:56 AM
VI Cutty's Avatar
Wouldn't the "horn" protrusion identify this as an 8.2" axle? The squared one is the Olds corporate under my '71 Cutlass. The car is 52 years old, they've "only" had it for the last 40 so there's a period of 12 years where parts might have been swapped.
Best person to talk to is Monzaz on this board.
Old Jan 28, 2023 | 10:19 AM
The one-sided "V-notch" feature in the cover is correct for the 1971-72 corporate 8.5. There is no doubt in my mind, but if it makes one sleep better at night, pull the cover and actually look at the parts inside. Here are more photos of the ears on a corporate 8.5" ten bolt under various 1971-72 Cutlii.
Old Jan 28, 2023 | 11:45 AM
monzaz's Avatar
If you feel the top of the casting you will feel and or see the brake line has a BOSS tapped and drilled for the brake like brass hose end fitting. that is 8.5 only.
8.2 CHEVY AND 8.2 bop HAVE BRACKETS THAT BOLT TO THE COVER BOLT TO HOLD THIS LINE to the rear.
That should help you. Jim
JD RAce
Old Jan 28, 2023 | 01:05 PM
My original 8.5” 10 bolt has a block “O” and parallel ribs on the side. Much better ID features than the cover and horns / no horns.
Old Jan 28, 2023 | 03:08 PM
However you will note that yours also has the same "horn" features as on the OP's axle.
Old Jan 28, 2023 | 03:29 PM
2blu442's Avatar
Since we all like pictures here's an 8.2" with the brake line bracket monzaz mentioned. The OP does not have this so that's one more bit of information confirming he has the 8.5"
Old Jan 28, 2023 | 06:00 PM
Joe, I never even noticed that as I have never used the horns / no horns as an identifier. Had this rearend since 1990 and never even noticed those horns.
yeahbuddy
Drivetrain/Differentials
May 17, 2021 04:34 AM
Cory Kloter
Sep 4, 2019 07:10 PM
anthonyP
Dec 19, 2015 07:20 PM
davidstereo
May 21, 2012 11:53 PM
monzaz
Apr 20, 2008 07:15 AM
