1971 cutlass rear end GEAR Question
Old Jan 22, 2020 | 10:48 AM
Fonz's Avatar
I have a 1971 cutlass ragtop, with a 2.56 "rear gear" in it. Also I Have a 1973 8.5 camaro 3.08 "ring and pinion". can the 3.08 be just swapped in, or do I have to change the Carrier ??? Thanks
Old Jan 22, 2020 | 11:49 AM
The 2.56 gears use a different series carrier than the 3.08 gears, but you can mount the 3.08 ring gear on the 2.56 carrier using a ring gear spacer. The spacers are made just for this type of gear swap.
Old Jan 22, 2020 | 01:00 PM
The Camaro carrier will fit in your Olds housing, though I don't know how the axle splines match up. Yeah, I know the Camaro uses C-clips and the Olds uses bolt-in axles.
Old Jan 22, 2020 | 01:02 PM
Fonz's Avatar
THATS WHAT I FIGURED. WAS LOOKING AT your "COMBO", that is a 355 OLDS, correct ? not 355 chevy? if so, what did you do about the LOW compression of the Olds engine ??
Old Jan 22, 2020 | 03:52 PM
monzaz's Avatar
camaro carrier can be used in the 71 72 BIA cutlass 8.5 rear. The cutlass non c-clip carrier CAN NOT be used in the camaro as it will not have the recessed pocket for the c-clip to seat in.
PLUS the fact that the 2.56 is a different series than the 3.08
Carrier break 8.5 GM corp. 1971 -1987
2.41 - 2.56 = 2 series carrier
2.73 - 4.56 and all the way to 5.57 are all on the 3 series carrier
All are 28 spline carrier at 45 degree spline pitch.
Jim
JD Race
Old Jan 22, 2020 | 04:03 PM
Fonz's Avatar
so Both a 71 cutlass carrier and a 1973 camaro Carier Both have "28 tooth count " axles? thanks. I Have a 73 camaro 2.73 carrier.
Old Jan 22, 2020 | 04:46 PM
I didn't mention anything about the 3.08 carrier fitting into your 2.56 rear because you said you had 3.08 gears with no mention of having the carrier, and by putting quotes around the 3.08 "ring and pinion" made it sound like all you had were the gears.
Yes, a 355 Olds engine. In order to get it to 355 cubic inches, the block was bored .030" and new pistons were installed. With new pistons I had a choice of dish sizes beyond the 1971-1972 factory 24cc soup bowls. Long story short, the rebuild included 6cc dished pistons which raised the compression.
Old Jan 22, 2020 | 08:23 PM
monzaz's Avatar
Remember one can fit into one but not the other because of c-clip axles. and bolt in axle side gear pockets being present or not.
slade69
Drivetrain/Differentials
Jan 12, 2020 07:17 PM
onetogofast
Jul 25, 2015 02:48 PM
Big Leche
Aug 2, 2013 06:57 AM
michael hilsabeck
Jan 8, 2011 11:38 AM
65Delta88
20
Jan 14, 2009 07:15 PM
