1970 O-Type replacing a 1971 8.5 Corporate
Will a 1970 A-body O-type 12 bolt rear replacing a 1971 Cutlass Supreme 8.5 Corporate rear require any changes? I've read that the diveshaft will need to be changed, but I've also read info that states that it would be a direct swap with not alterations.
Driveshaft could need to be about 1 longer...BUT you may not have an original driveshaft in the car after this many years.
BUT YES, normally and swap with a 8.5 the driveshaft will need a lengthening or shortening depending on if you are swapping it in or out with another NON 8.5 Corp 71 72 rear.
Jim
JD race
Jim
JD race
Nafets
Feb 14, 2025 01:39 PM
redwings372
Drivetrain/Differentials
Nov 4, 2012 06:25 AM
monzaz
Mar 4, 2010 06:49 AM
