1969 axel/differential question
Old Jan 12, 2021 | 02:19 PM
old greybeard's Avatar
69 Cutlass S
Just bought a 69 Cutlass. 350 4b, Canadian built. Trying to determine ratio and if limited slip, want to change fluid with correct type.
Can't find a axel code.
And the differential is interesting, 3969278, F89 build, June 8 1969. Which is correct, my build date is 3rd week June 69. I have read that Canadian Cutlass's had Chevy rear ends.
Interestingly that diff is for 70-72 Chevelle's. Did find a site which had a 70 Chevelle that had that # with a build date in June 69, said it was built by McKinnon Industries of Canada.
They mentioned that several had no axel code or a code which could not be cross referenced.
Is the code ever found anywhere than the top of the PS axel? Any easy way to tell if its a LS?
Differential looks like it has never been opened.
Old Jan 12, 2021 | 02:40 PM
You can determine what fluid to use once you remove the cover. You can figure out the ratio by seeing how many turns of the tire vs turns of the driveshaft.
Old Jan 12, 2021 | 03:55 PM
Yellowstatue's Avatar
The axle code should be on the passenger side about six inches from the diff and upside down. Check both front and rear of tube.
Old Jan 12, 2021 | 06:11 PM
Well, if it leaves two black stripes behind the car on a launch, that's a very good clue that it's a limited slip.
Old Jan 13, 2021 | 07:51 AM
69 Cutlass S
will do, I had thought they were on top of the tube. Will clean the whole passenger side. 52 years of grime.
Old Jan 15, 2021 | 07:29 PM
cjsdad's Avatar
My 67 has a GM 12 Bolt and it looks factory, not sure. But the ID stampings are on the front of the passenger side tube.
Old Jan 17, 2021 | 10:57 AM
monzaz's Avatar
12 bolt chevy rear
2.73 that is a Chevy 12 bolt rear.
Not even a POSI code....KDC is open 2.73 chevelle elcaminio - So I would say that is not going to do you anygood.
Open the rear and spin the ring around till you find some numbers on the outer diameter of the ring gear shoot a picture will decipher it
Old Jan 17, 2021 | 11:29 AM
69 Cutlass S
Found my axel code
Its the correct date and location for the build, Mckinnon June 17
Axel code is RA. Can't find a cross reference. Any ideas?
Old Jan 17, 2021 | 12:25 PM
I would expect the 2.78:1 ratio is actually a Type O and that listing is, well, a typo.
Old Jan 17, 2021 | 12:52 PM
Per the chassis manual...Type "C" RA = 2.73 (41:15).
Old Jan 17, 2021 | 01:28 PM
69 Cutlass S
Thanks had found that site after I posted
It is a 69
2.73 or 2.78
Canadian car, Chevy rear end.
Old Jan 17, 2021 | 02:03 PM
I suspected same.
EDIT: However, if you review the 1966 model year, you'll find the 2.78:1 listed several times. An interesting note (I guess) is during this time period various rear-ends, whether they began with the letter "R", or the letter "Q", or the letter "S" (and, I've seen this elsewhere on printed material) - those rear-ends generally always fall w/in the 2.XX range (i.e. 2.56:1; 2.73:1; 2.78:1). And, apparently the number of teeth support the change - not sure.
Correct, there were 8.2" 10 bolt rears from Chevy, Pontiac, and Buick in those years. Different ring and pinion tooth counts gave similar, yet slightly different, ratios.
Old Jan 18, 2021 | 11:42 AM
Cheese Norm, now I have to create a new folder for all these certificates I am being awarded with.
Old Jan 18, 2021 | 05:43 PM
monzaz's Avatar
ratios
2.78 will always be a B O P ratio (14 - 39 tooth count)
2.73 is normally chevy 10 or 12 bolt c-1lip rear (15 - 41 tooth count)
68-70 Buick did use the 2.73 also (8.25 odd rear large driver side carrier bearing 1.875 pinion shaft)
8.5 also used the 2.73 ratio and became a 3 series gear... lol.
Wacky stuff over the years.
then 7.5 10 bolt metric 2.73 became a 2 series gear ratio
Jim
JD Race
arcticman
Jun 21, 2020 08:23 AM
Mike H.
May 14, 2016 01:05 PM
droptopron
Feb 9, 2016 05:45 AM
Stefano
Jul 20, 2015 06:51 PM
Bernhard
Nov 9, 2013 08:59 PM
