1967 442 3.55 Questions
Old Mar 22, 2012 | 11:32 PM
Threejdsolds's Avatar
I responded to an ad for a differential out of a 1967 442 4-speed. Turned out the guy was stripping the car, so I bought what was left. The guy was a butcher. I did get the original CA black and yellow plates and a title. Doors and glass appear to be good. Back window leaked and the trunk is a mess. I cannot find any letters on the passenger side axle tubes. There is an "H" on the back of the driver side axle tube. The # on the housing is 9788647.I was reading a thread about 4 pinion units vs 2 pinion units. Attached are pictures. Is it possible to tell from the pictures what unit this is?
Old Mar 22, 2012 | 11:58 PM
Nufo's Avatar
there's hope ...
I wish I knew more about the rear ends, but I don't.. someone on this site will know and they will let you know. I'm sure of that... what kind of things are still left on the car that are good.. shame people have to butcher things that can't be replaced. takes all kinds I guess. I am looking for a few things if you are interested in selling parts... Thanks - Fred
Old Mar 23, 2012 | 06:04 AM
TripDeuces's Avatar
Looks like a 4 pinion unit. 4 small gears spaced 90' apart. Brian Trick will chime in and set you straight.
Old Mar 23, 2012 | 06:17 AM
wmachine's Avatar
Trying to remember member
Definitely and 8.2 4-pinion cone type P rear. Which is a Pontiac rear correct for a '67 Olds. If you look in the window of the carrier, you see 2 of the pinion gears at 90 degrees apart. That means there are 4 of them. The best of the earlier 10 bolt rears. Visible on the edge of the ring gear will be stampings showing the ratio and date codes.
Old Mar 24, 2012 | 10:08 PM
Thank you guys for your help. The car is too far gone for me to take it on as a project. I am going to use the rearend in my 64 Cutlass. Guess I will put the car up for sale.
Old Apr 5, 2012 | 09:23 PM
monzaz's Avatar
rear info
Yes the w-cars received the PONTIAC rears in the early 1967 the late 67 got the 122 bolt olds / o type which is a 12 botl cover and 10 bolt ring gear.
That really is a PONTIAC rear end in a olds...It was the strongest rear of its day for the BUICK PONTIAC AND OLDS cars. Until the 12 bolt OLDS rear was introduced.
Be sure to service the posi unit if you can open the posi and inspect the cones for bottoming out. Remember this is a 40 year old posi so do not expect it to be like NEW. Jim
f-85
Jan 19, 2014 07:55 PM
cheffernan
Oct 13, 2012 05:38 PM
Big Todd
Nov 2, 2010 12:24 PM
krobsklassics
May 12, 2009 08:33 PM
WisconsinDelmont
Apr 17, 2008 05:03 PM
