10 bolt swap
Old Jun 27, 2012 | 07:18 PM
Saulpocolipse's Avatar
10 bolt swap
Started a rear end swap on my 67 cutlass. Going from the original 12 bolt to a chevy 10 bolt. The 12 bolt is pretty worn out, she growls and howls on the highway and parts seem to be pricey. The 10 bolt is from a 72 chevelle, and I temp installed before painting and replacing seals and it fits perfectly. Still need to find a u~joint to fit but that should be easy enough. I will post some pics tomorrow. Let me know if you would like any more info on how this swap is going, I would be glad to share.
Old Jun 27, 2012 | 07:22 PM
joepenoso's Avatar
I would like to know
joepenoso
Old Jun 27, 2012 | 08:42 PM
2blu442's Avatar
The Oldsmobile has a larger diameter cap and I think it's longer between the caps. I've got a Chevelle 12 bolt under one of my cars and found the correct u-joint at the local NAPA dealer. I just told them what I needed and they came up with it, two caps to fit the Chevy rear end and two caps to fit the Oldsmobile driveline. John
Old Jun 27, 2012 | 09:26 PM
Sweet, thanks for the info! For sure the caps on the olds are larger and do not fit the chevy yolk. I was going to hit up napa and see if they actually had a u joint with 2 different sized caps (wishful thinking) and was assuming I would end up peicing something together. That will help out a lot at the parts counter. Other than that, this has been a "plug and play" installation. Everything else matches up nicely.
Old Jun 27, 2012 | 09:29 PM
joepenoso
You got it. I will get some pics, and when I get the u joint together I will post part numbers as well.
Old Jun 28, 2012 | 06:08 AM
joepenoso's Avatar
Originally Posted by saulpocolipse
you got it. I will get some pics, and when i get the u joint together i will post part numbers as well.
thank you
joepenoso
ggoudas
Drivetrain/Differentials
20
Jan 18, 2013 10:45 AM
leepear
Nov 9, 2011 10:10 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
mcutlass1969
Feb 12, 2008 08:59 AM
kayle
Dec 24, 2007 06:03 AM
