10 Bolt Help
Old Jan 10, 2011 | 07:34 AM
  #41
507OLDS's Avatar
If the gears are good,then at least you have an 8.5" rear with 3:08's that are set-up for that rear,so it is something that you can still redo yourself.I would think if the seller knew those pieces were in there,he would have drained everything out.IF all of the teeth are good on the ring & pinion,then it's a little more obvious that it's the posi unit.Remove the axles & take the unit out.I use paint thinner at times.It works real well against the gear oil,and leaves everything as dry as it was when new.
You guys would love to see the one I opened yesterday.From the outside,it looked mint.No pitting or anything.The inside was a completely different story.Obviously water got in somehow,then couldn't get out.Part of the open unit was froze-up with rust.I'll get it knocked apart,then off to the hot tank.
Old Jan 10, 2011 | 11:31 PM
  #42
Wyze's Avatar
Thanks Brian!!!
What's a good unit run & what type should I be looking for?????
Is it also true any 8.5 will fit, even out a truck?????
Drew
Old Jan 11, 2011 | 05:09 AM
  #43
507OLDS's Avatar
Any 8.5" posi unit for 28-spline axles will fit.A lot of the truck used what they call a gov-lock posi,and you don't want one of those.
An Auburn unit is a cone style,very similar to what you have now.Those are about $350.00 with the shipping.The eatons are a clutch style,and are rebuildable.Those are about $425.00 with the shipping.
Old Jan 11, 2011 | 05:41 AM
  #44
Wyze's Avatar
Good looking out Brian!!!! Clutch type is what I wanna go with since it can be rebuilt!!!!
We got 6" of snow overnight!!!! So it'll be a couple days before I get it cleaned all the way out and take more pics!!!!!
I'll be checking flEa Bay for to see if I can win a Eaton unit!!!!!!
Thanks Drew!!!!
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
