10 Bolt Help
Old Jan 5, 2011 | 09:55 PM
Wyze's Avatar
10 Bolt Help
I looked all over this thing and could not find any numbers on the outside!!!
Can someone help to identify it from this pic and numbers from inside!!!
123477:40-13:GMC
Thanks Drew
Old Jan 5, 2011 | 10:07 PM
Wyze's Avatar
Looking at the yellow paint would you say it's had some parts replaced from the junkyard??????
Old Jan 6, 2011 | 04:36 AM
InfoJunkie's Avatar
InfoJunkie
It is a BOP 8.2" limited slip diff with 3.08 gears. Unsure of year but not 64'. Has bolt in 28 spline axles and a 27 spline pinion. That's my best guess.
Old Jan 6, 2011 | 04:50 AM
507OLDS's Avatar
Looks like an 8.5" 10-bolt,3:08 posi. The posi unit is a cone style. This probably came from a 71-72 Buick Skylark/GS. If I saw the rest of the rear,I would know for sure.The codes that were stamped on the outside,were on the passenger side axle tube,facing the front.Look between the pumpkin,& the spring perch.As long as the tube isn't too rusty,they should still be there. You should also find a large "A" on the top of the pumpkin,and the cover is smooth,with notches at 9:00 and 3:00.
Old Jan 6, 2011 | 04:52 AM
Wyze's Avatar
Not to sound like an *** but how can you tell it's a 8.2 and not 8.5??????
I heard that if it has 3/4 bolts it's a 8.5!!!!!!!
Brian I just saw you post, it maybe did come out a 72 Skylark but they weren't sure!!!!!!
Old Jan 6, 2011 | 04:58 AM
Wyze's Avatar
Is the cone the good type of unit or the bad????
Old Jan 6, 2011 | 06:00 AM
507OLDS's Avatar
The 8.5's are enlarged above & below the ring gear,for the larger gear,compared to an 8.2". The pictures are not the greatest,but everything appears to look like an 8.5".
The cone style is fine for a cruiser,but I prefer a clutch style unit for anything I build,or for anything with good power going to it.
Old Jan 6, 2011 | 06:23 AM
monzaz's Avatar
10 bolt 8.5
Brian you are correct. 8.5 Bearing caps are the dead give away - Olds 12 bolt uses the same caps BUT since this has 10 bolt cover we know for sure it is not that...lol.
Also as the other gentleman said 3/4" bolt heads (another point to 8.5). side note (69 70 71 72 pontiac 8.2 did use 3/4 headed bolts too that are reverse thread 7/16") ALso the lower 5-7 o'clock castings are there as all 8.5 rears have. CAT ears / or shark teeth I guess people call them...lol
The posi is a Borg Warner cone type...Some were used in chevy rears also then they used all trac Lock units with clutches later. This is probably a 71 because of the BW unit... Looks pretty original.
So if the rear has bolt in axles and flange to flange is 55 1/4" you have your self a Buick or Olds 71 72 A -body rear that will bolt into any 1967 -1972 BOP or 1968-1972 Chevy...with some slight drive shaft mods if the not a 71 72 cutlass or Buick skylark which obviously are a DIRECT FIT.
Great find - clean it up put some new bearings in it, check the posi and have some fun with it. JIm
Old Jan 6, 2011 | 07:08 AM
Wyze's Avatar
Nks guys!!!!
What do you all think is a good (fair) price????
Old Jan 6, 2011 | 07:09 AM
Wyze's Avatar
Oh and yes I wanna put it in my 68!!!!
Old Jan 6, 2011 | 07:23 AM
507OLDS's Avatar
It will go into your 68,but you will need to shorten your driveshaft,as Jim stated.That is the only modification needed.All of the mounting points & brake parts are the same.
Old Jan 6, 2011 | 08:09 AM
Wyze's Avatar
Hey Brian, I think he said it'll bolt right in my 68 Cutty!!
I'd have to mod if I had a Chebbie????
Smh!!!!
Well Can I go get a Buick driveshaft????
If not, how much does it cost to shorten
What's the going rate for this rearend???
Thanks Drew!!!
Old Jan 6, 2011 | 08:31 AM
507OLDS's Avatar
If your car has a TH350 trans,then just get a driveshaft from a 71-72 Cutlass with a TH350. That would be the correct length.
The value of that rear,as-is,about $500.00 give or take.
Old Jan 6, 2011 | 09:28 AM
Wyze's Avatar
Yeah I've got a TH350 trans already!!! That will not work???
I'm not trying to be a pita but I'm still a little confused!!!
Old Jan 6, 2011 | 09:46 AM
507OLDS's Avatar
Yes,the trans doesn't matter. What is different is the 8.5" 10-bolt rear has a longer pinion snout,compared to the 12-bolt O-axle,so it needs less shaft to reach it.
Since you would be installing the rear into your 68,with a TH350,you "could" find a shaft from a 71-72 Cutlass that also had a TH350,since it would also have that 8.5" rear.Make sure it is a 2-door.
If you need the exact measurement for that particular shaft,I can get it for you,so you know what to look for.
Old Jan 6, 2011 | 10:23 AM
Wyze's Avatar
Gotcha!!!! Now I understand!!!
I asked about a price because my buddy told me I had stole the thing for what I paid for it!!! ($250)
I just called the guy I got it from to see if he had the driveshaft!!!
He said he's pretty sure it came from a 72 Skylark!!!
Can I use that one???
Old Jan 6, 2011 | 10:30 AM
Wyze's Avatar
How do I check the posi & bearings?????
Thanks Drew
Old Jan 6, 2011 | 10:48 AM
507OLDS's Avatar
Can't complain about that price.Clean it up & re-bearing/seal it,and it should be good for quite awhile.If he has the shaft,and you can get it real cheap or free,get it.I don't know what length the Buicks had though.
Here is a breakdown of ALL of the bearings & seals in that rear:
Pinion,inner bearing = M802048
Pinion,inner race = M802011
Pinion,outer bearing = M88048
Pinion,outer race = M88010
Pinion seal = 2043
Carrier bearing = LM501349(need 2)
Carrier race = LM501314(need 2)
Axle bearing = SET9 or also known as A9(need 2)
Axle seal = 712146 or 2146 ***These seals have different thicknesses.Most of the A-casting 8.5's have needed the thinner 2146,but if you get the 712146,it will work.You just don't want the axle to slide in/out at all when it's all torqued in there.This is part of the job of the seal.
Ring gear bolts = 65ft-lbs with red Locktite
Carrier cap bolts = 65ft-lbs no Locktite
Old Jan 6, 2011 | 11:05 AM
Wyze's Avatar
Thanks!!!
He's looking for the shaft!!!
What's those measurements for a 71-72 2 door with a TH350 driveshaft?????
Old Jan 6, 2011 | 11:23 AM
Wyze's Avatar
How do I check the posi????
Old Jan 6, 2011 | 02:44 PM
dsa2207's Avatar
Brian,
Will an Auburn 8.5" Posi unit fit that housing?
Craig
Old Jan 6, 2011 | 03:32 PM
InfoJunkie's Avatar
InfoJunkie
I was just going by the shape of the gasket that was on the housing.
1971 GS diff cover gasket in the first pic 8.5
1968 GTO diff cover gasket in the second pic 8.2
I did say it was a guess but after hours of searching online, I still can't find a pic of an 8.5 that takes the pic 2 gasket.
Old Jan 6, 2011 | 06:53 PM
monzaz's Avatar
10 bolts
The 10 bolt 8.5 1971 72 73 74 Buick olds Pontiac rears have the same scalloped LOOKING <--- stress on the LOOKING...because they are NOT the same as the 8.2 10 bolt cover in bolt hole pattern.
EASE way to tell the difference in the 8.5 cover and the 8.2 cover with the scalloped cover is -
10 bolt 8.2 cover has a cut in the top of the rim edge of the cover 12 o'clock bolt for the chassis brake hose bracket to mount about a 1/2" cut.
The 10 bolt 8.5 does not and has little rim bulges at the 12 and 6 oclock rim edge. ALSO the 8.5 has a boss at the top of the cast housing inbetween the upper control arm ears where the chassis hose mounts. It is taped for a 5/16 bolt.
That is it... now everyone should have very good info to ID the 8.5 from a 8.2. Jim
Old Jan 6, 2011 | 06:57 PM
monzaz's Avatar
10 bolt 8.5
Originally Posted by dsa2207
Brian,
Craig
all 8.5 UNITS ARE INTERCHANGEABLE eVEN THE 30 SPLINE 8.5 UNITS FROM 1990 -1996 WILL FIT THE HOUSING. Even the truck units will fit the 1971 housing. 8.5 is 8.5 .
YES-
This rear is 28 spline so you should make certain the aftermarket auburn unit is 28 spline.
Old Jan 6, 2011 | 07:07 PM
monzaz's Avatar
posi
WELL the best way is always to unbolt the unit and disassemble it to see how close the cones are to the bottom of each 1/2 they wear into. IF you see any shiny spots on any of the flat surfaces NOT the conical area that will look scarred (normal)
If the bottom of the cone 90degree surface or tower in the bottom of the case is rubbed shiny then the cone has bottomed out and the posi is worn out. We can machine the cones and reshim the unit to work again but it will only be a fix and we never know how much life is given back. I have done many and keep checking back with customers to see how they are running - 2 years on one so far pretty hard spirited driving.
again reference pictures.
red arrows show where the cone bottoms out in the case- This is a newer auburn unit and will be slightly different from yours inside but it will be roughly the same deal. Jim
Old Jan 6, 2011 | 07:33 PM
InfoJunkie's Avatar
InfoJunkie
Thank you for the info on the difference.
Old Jan 6, 2011 | 10:37 PM
Wyze's Avatar
Originally Posted by infojunkie
thank you for the info on the difference.
x2!!!!
Old Jan 7, 2011 | 04:50 AM
dsa2207's Avatar
thanks
Old Jan 7, 2011 | 08:10 AM
507OLDS's Avatar
And thank you for taking pictures & posting them. I never have my camera when I need it.
Old Jan 7, 2011 | 12:07 PM
monzaz's Avatar
pictures
Yah the picture say so much more than words ever do. I love that feature on the sites cause trying to explain and then terms from one person to the next differ etc. :0 Good luck on the rear.
Old Jan 8, 2011 | 05:19 AM
  #31
507OLDS's Avatar
Who needs Bill Cosby,when we have Picture Pages right here.
Old Jan 9, 2011 | 11:14 AM
  #32
507OLDS's Avatar
The driveshaft that you will need,for a 68-72 Cutlass,with a TH350 transmission,and the 8.5" 10-bolt rear,is 55" from center of u-joint to center of u-joint.
Another note: The A-casting 8.5" 10-bolt,which are the ones with the notched cover that look like the BOP 8.2",originally came with the squiggly gasket,and the O-casting 8.5" 10-bolts,with the round cover with the protruding rib from 12:00 to 3:00,came with the wider/solid gasket.
Old Jan 9, 2011 | 12:07 PM
  #33
Wyze's Avatar
Bad news!!!!
I was just trying to clean oil out the rearend and found some metal inside of it!!!
Smh!!!!
I couldn't see it at first but I do now!!!!!
I've heard that's a very bad sign!!! Just my luck!!!!
I'll get pics after I warm up and go back out in the garage!!!!!
I'm pissed!!!!!!!!
Old Jan 9, 2011 | 01:04 PM
  #34
507OLDS's Avatar
Is it chunks of metal,or powder/dust?
Old Jan 9, 2011 | 02:30 PM
  #35
Wyze's Avatar
Unks, I saw them when emptying the fluid so I guess they were resting on the bottom!!!
It really spoiled my mood that's why I haven't posted pics of it!!!!!
Let me guess-------- Bad posi unit??????
Old Jan 9, 2011 | 06:31 PM
  #36
507OLDS's Avatar
Get it all cleaned-out,and see what the ring & pinion teeth look like.
Old Jan 9, 2011 | 07:48 PM
  #37
Wyze's Avatar
Can you tell anything from the pics??? Jk!!! Lol!!!
I'll try to get it done tomorrow!!!
What should I be looking for?????
Old Jan 9, 2011 | 07:59 PM
  #38
Wyze's Avatar
And I'll also get pics of the metal!!!!
Old Jan 10, 2011 | 05:25 AM
  #39
monzaz's Avatar
ring gear
Well the ring gear appears to be in good condition sop I am sure the pinion is fine also.
POsi you will never know until you remove the unit and tear it apart. You can do a inthe rear torque test but it is unreliable at BEST.
There is always going to be some metallic silt if you have large sharpe shaving or chunks YAH you could have an issue. Best thing is to take a gallon of kerosene and pour it in after you let the rear drain upside down for a day 2 days if your in the COLD weather states....LOL. Jim
Pour the kero in after and get a brush clean it the best you can turn the pinion round and feel how much grit you have... after you think you got the OLD oil broken down enough dump the kero into a seperate pan from your oil so you can still use some of the fluid for cleaning after you remover the carrier too. OF if you have plenty of clean just pitch it and use new. Jim
clean clean clean....
Old Jan 10, 2011 | 06:11 AM
  #40
Wyze's Avatar
Lol!!! Yeah we posed to get 2-5" of snow today so it'll prob be a couple of days!!! Smh!!!
I'll keep you posted!!!
I was thinking that guy might have known those metal chunks were in there!!!!
My reason for saying that is how easy the cover came off & the price he sold it for ($250)!!!!!
