Valvoline VR1 - anyone use this?
Hey are any of you guys running Valvoline VR1 in your flat-tappet engines? I recently read where this oil available in both conventional and synthetic contains high amounts of zinc - a great lube for old style cams and tappets. I've been using Castrol GTX 10-30 dino oil.
Any bonus using the VR-1 "Racing" oil? If so, synth or conventional? Or has marketing hype set in but again?
I use VR1 and we've discussed this many times.
Here is a good read.
http://540ratblog.wordpress.com/
^ oops, got excited thinking it was a newer product. Should of searched.
When Googled, a Chevelle forum had a few threads discussing VR1 synth vs. dino with no conclusion to be had. The other sword fight they had was over straight wt. vs. multi.
So far I picked up more zinc is a good thing if you don't run cats. The oil blend with other additives is important not necessarily zinc alone. Heavy multi-weights are best suited for engines with large main bearing clearances. Some swear by their favorite dino brand with Edelbrock break-in additive (heavy zinc) with every change. Eric's link demonstrates Eldelbrock's zinc often INCREASES wear from the factory blend. Mutli-weight is superior for cold start-up.
Talk about over thinking stupid oil! We'd dump in Quaker State 30, paraffin based Junk Oil in the 70's and rip around fine. Just had to de-sludge the poor devils every now and then. Great link, answered all my questions. VR1 10-30 silver bottle for the win.
JpMotorsports
May 15th, 2014 07:08 AM
GAOldsman
May 12th, 2011 04:23 AM
