Intake / Vacuum Question
Old September 12th, 2013, 06:40 PM
extremewillis's Avatar
Hello! I'm trying to replace my stock manifold / carb with an Edelbrock 2711 intake and 1406 4bbl carb. I've done some reading but can't figure out what this is? Can I get a 'lil help? These small vacuum lines just run from the front of the intake to the back. Can I just block off this spot when I put on the new intake? Also there's 12 volts at the wires - can I use that line for my electric choke? Thanks! and one more - there is a small vacuum line running to small cone shaped think attached to the back of the HEI distributor - what is that??
for my 71 Cutlass Supreme
Thanks!
Aaron
http://postimg.org/image/7fmi6v00h
extremewillis is offline
Old September 12th, 2013, 06:55 PM
Found it! Read some more threads. Thank you Joe Padavano
It's a DTVS. And the thing in the back is the distributor vacuum advance
The sole purpose of this switch is to run full manifold vacuum to the distributor if the engine gets too HOT.
Now just need to answer my last question - can I use that same electrical line to power my electric choke?
Old September 12th, 2013, 07:02 PM
Nope. I really am asking. can you offer some advice?
Old September 12th, 2013, 07:54 PM
Hey Eric! I see that you have already answered this question in a previous thread.
Quote:
Originally Posted by bonnevillegreg View Post
Would it also be possible to use the electrical feed formerly used for the Distributor Vacuum Control Switch?
Yes, the feed wire (green or green and black, if I recall) should be hot when the ignition's on, and should be fine for this.
Old September 12th, 2013, 07:56 PM
I have decided to try bypassing the DVCS and connecting the distributor advance to a manifold or carb vacuum port. Thanks to the forum for being a great resource.
Aaron
Old September 13th, 2013, 06:33 AM
I love it when someone answers their own question.
As for the electric choke, read this thread.
joe_padavano is offline
pogo69
January 28th, 2013 03:49 PM
rmoths
September 3rd, 2012 04:40 PM
svnt442
July 17th, 2011 04:43 PM
KZ442
February 4th, 2011 09:26 PM
sworthy555
February 26th, 2009 06:13 AM
Quick Reply: Intake / Vacuum Question
