'65 Cutlass trans kick down adjustment?
Old Apr 22, 2013 | 05:14 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Does anyone know if you can adjust the kick down switch to make it downshift sooner besides the throttle rod? Right now I have to just about stomp a hole in the floorboard to make it kick down into 1st and I don't know how much more threads are left in the throttle rod. This is on a '65 Cutlass that we put a 425/T400 combo in.
Old Apr 22, 2013 | 05:38 PM
Since the 65 did not come with a T400 what are using for and where is the location of the kickdown switch?
Old Apr 22, 2013 | 06:40 PM
66 Olznut's Avatar
It's the stock one the car came with. Jetaway and T400 share electric kick down and the harness also plugs right in.
Old Apr 22, 2013 | 06:56 PM
Octania's Avatar
did yo ck the output of the KDSw and verify that it puts out 12V near WOT?
Ck the trans tang for some ohms, so if 12V gets there it can do something?
Old Apr 22, 2013 | 06:59 PM
Here are 2 threads, 1st was for my car, and the second has more info. I was under impression the 65 setup had a seperate kickdown switch hooked to the carb, I may be mistaken.
https://classicoldsmobile.com/forums...djustment.html
https://classicoldsmobile.com/forums...pitch-mod.html
Old Apr 22, 2013 | 07:05 PM
66 Olznut's Avatar
It works, just have to pretty much put my foot through the floor to make it downshift. My '66 kick down is identical to the '65 I'm working on now, thanks for the links, good info in there.
Old Apr 22, 2013 | 08:32 PM
My switch is all messed up I just haven't gotten a chance to swap it out. I might just set one up on the carb and be done with it. So right now I just manually shift it down.
mat1227
Oct 16, 2013 03:41 PM
cutlassjoe
Oct 14, 2011 04:41 PM
DRXOLDS
Aug 24, 2011 10:47 PM
highlander
Apr 16, 2010 10:28 AM
salisbury99
Jul 5, 2008 05:26 PM
