differences between 70 and 71 doors??
You are usually good to swap doors.If the 70 door had a 70 sport mirror,then it will have different openings in the door for the mirror,compared to 71-72.The only other thing to check is to see if the donor door has the same glass as your car,either clear or tinted.If it is different,then you will need to reuse your glass.
yamahondarider
November 26th, 2014 04:51 AM
66Dynamic
April 17th, 2014 04:52 PM
64 Cutlass
January 22nd, 2010 06:59 AM
