Throttle cable for 68 cutlass 350 4bbl
It appears that an aftermarket throttle cable is not made for the 68. All the ones I see have the larger hole that the grommet goes in for the carb. I even tried using the little retainer that goes on the gas pedal from a 1972 and my throttle cable end slips right through it. Had to put the chewed up one from my original gas pedal in when I switched to the TH350. Please tell me I am wrong and there is one out there....
I thought 1968 [only] had the stubby 1/4" peg that requires a narrow version of the rubber and plastic pcs pictured above.
Let's see the G-body item!
see the peg on this
http://api.viglink.com/api/click?for...mp%3Bvxp%3Dmtr
see the peg on this
convert69
Sep 6, 2011 05:27 PM
cutlass1972s
Jul 6, 2010 06:33 PM
70Post
Mar 1, 2010 08:19 PM
