'68 outside door handles 2 vs 4 doors
I am sure some one will know this off the top of their heads....
Do two door and four/wagons '68 Cutlasses use the same outside door handles?
Adam
Adam
Om my Vista the outsides of the handles are exactly the same but the button in the rear has a much longer shaft with a T piece on the end to depress the release lever inside the door because it sits in from the door face more than the front.
Makes it a bear when the car's apart, you can't reach the lever with your finger to open the door like the front.
halfmoontrail
Feb 22, 2013 12:14 PM
