'68 outside door handles 2 vs 4 doors
Old Nov 1, 2010 | 01:32 PM
arodenhiser's Avatar
STOP call'n it a Chevelle
I am sure some one will know this off the top of their heads....
Do two door and four/wagons '68 Cutlasses use the same outside door handles?
Adam
Old Nov 1, 2010 | 05:34 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I know this doesn't help you, but the 80's cars will swap between 2&4 door
Old Nov 1, 2010 | 06:36 PM
As far as I know, same as Chevy and Pontiac, too.
Caddy was different (not sure about Buick).
Old Nov 2, 2010 | 06:20 AM
66400's Avatar
Part numbers...
Handle, door, front
2drs 7652236-7
4drs 4808646-7
Handle, door, rear
4drs 7729580-1
Henry
Old Nov 2, 2010 | 07:57 AM
Bluevista's Avatar
Registered
Om my Vista the outsides of the handles are exactly the same but the button in the rear has a much longer shaft with a T piece on the end to depress the release lever inside the door because it sits in from the door face more than the front.
Makes it a bear when the car's apart, you can't reach the lever with your finger to open the door like the front.
delta69
May 19, 2014 07:36 AM
HonestDave
Jun 27, 2013 07:19 PM
halfmoontrail
Feb 22, 2013 12:14 PM
Ronin775
Body work
Nov 10, 2012 02:00 PM
Olds Dad
Feb 22, 2011 06:24 AM
