1972 is it rare
Old Jun 7, 2018 | 11:12 PM
Gregory Neil O'Rear's Avatar
1972 is it rare
I have a 72 and want to know if it's rare or kinda rare.
ST 72-34257 R. 01685 BDY
TR 970 A65 56 B PNT
08E 536
It's a U vin with an R in it.
3J57U2R
Old Jun 8, 2018 | 08:29 AM
Gregory, it is desirable, as it is a factory 455 car, but you should post your own thread as this one is 7 years old.
Old Jun 8, 2018 | 08:39 AM
I moved your post to its own thread instead of resurrecting one from 7 years ago.
Old Jun 8, 2018 | 03:11 PM
rcorrigan5's Avatar
Randy C.
Here's a breakdown of the trim tag.
ST 72 = style/model year = 1972
34257: 3 = GM division = Oldsmobile; 42 = model series = Cutlass Supreme; 57 = body type = hardtop coupe
R = assembly plant = Arlington TX
01685 BDY = Fisher Body number, which has no relationship to the VIN
TR 970 = interior color = black
A65 = option code for the notch back bench front seat
56 B PNT = lower body color (56) and upper body vinyl top color (B) = sunfire yellow body color with a black vinyl top
08E = time build code = August (08), fifth week of that month (E), 1971
Here's the breakdown of the front end of your VIN of 3J57U2R------.
J57 = Cutlass Supreme hardtop coupe
U = engine code = 455cid 4bbl carburetor. I believe it would also stand for the L75 set-up with dual exhaust and the THM 400 automatic transmission but that should be verified by someone else!
2 = model year = 1972
------ = assembly plant sequence number
I don't know if this car is particularly rare or not - those numbers are simply not available. But, like was previously mentioned, it is certainly desirable!
Randy C.
Old Jun 9, 2018 | 01:26 PM
U code production 1972 for A body Olds by model
3200 (f85 & Cutlass coupe) : 83 through June
3600 (Cutlass S, & Sedan): 2,359 through June
4200 (Cutlass Supreme) : 3,015 through June
4800 (Vista Cruiser) : 4,860 through June
Krom
Jun 9, 2025 04:38 PM
Lverschoot
Jun 15, 2017 08:08 AM
Rush1542
Nov 18, 2015 03:09 AM
kevin.horton
Sep 26, 2013 06:28 AM
Skitch72
Sep 20, 2013 09:39 AM
