1972 is it rare
Here's a breakdown of the trim tag.
ST 72 = style/model year = 1972
34257: 3 = GM division = Oldsmobile; 42 = model series = Cutlass Supreme; 57 = body type = hardtop coupe
R = assembly plant = Arlington TX
01685 BDY = Fisher Body number, which has no relationship to the VIN
TR 970 = interior color = black
A65 = option code for the notch back bench front seat
56 B PNT = lower body color (56) and upper body vinyl top color (B) = sunfire yellow body color with a black vinyl top
08E = time build code = August (08), fifth week of that month (E), 1971
Here's the breakdown of the front end of your VIN of 3J57U2R------.
J57 = Cutlass Supreme hardtop coupe
U = engine code = 455cid 4bbl carburetor. I believe it would also stand for the L75 set-up with dual exhaust and the THM 400 automatic transmission but that should be verified by someone else!
2 = model year = 1972
------ = assembly plant sequence number
I don't know if this car is particularly rare or not - those numbers are simply not available. But, like was previously mentioned, it is certainly desirable!
Randy C.
Randy C.
U code production 1972 for A body Olds by model
3200 (f85 & Cutlass coupe) : 83 through June
3600 (Cutlass S, & Sedan): 2,359 through June
4200 (Cutlass Supreme) : 3,015 through June
4800 (Vista Cruiser) : 4,860 through June
