Windshield washer runs continuous with wipers
Old Jun 10, 2018 | 12:04 PM
Rlasley's Avatar
My 67 Cutlass Supreme windshield washer didn't work even after replacing the motor. HOWEVER, now it's started working continuously whenever the wipers are on? Any thoughts on the cause? Do I have something reconnected incorrectly?
Rod
North Salem, IN
Old Jun 10, 2018 | 02:12 PM
Check to see if there is a ground to the washer terminal (dark blue wire). Or the actuator is hung in the on position.
Old Jun 10, 2018 | 02:51 PM
RandyS's Avatar
Inside the washer mechanism there is a pawl that gets engaged by an electromagnet and activates the pump actuator. There is a spring that returns the pawl to the off position after 1 rotation of the pump disc. If that spring has popped off, your washer won't turn off.
Old Jun 10, 2018 | 02:54 PM
razman427's Avatar
my 69 Camaro did the EXACT SAME THING! it didn't work at all, i ordered a replacement Anco unit, and after installing it, it pumped fluid any time the wipers were on. i checked everything, then sent the unit back and got a replacement....it worked flawlessly.
Old Jun 10, 2018 | 03:40 PM
In addition to this, if the arm on the pawl is bent, it will not engage properly and the washers will run continuously.
This happened to mine after around 30 years of use.
Neil F85
Jun 18, 2019 03:18 AM
My2nd 69 442
Oct 21, 2016 07:34 PM
ELECMAN
Feb 29, 2016 07:35 PM
Thomas Simcich
Dec 19, 2010 06:40 AM
Gustav455
Mar 5, 2010 03:41 PM
