Window runner
Old Mar 17, 2017 | 10:34 AM
Cutlass Fan's Avatar
Window runner
The lining is gone in the window runner at the rear of the drivers side door glass on my 65 convertible. I can't seem to find any company that lists them. I assume that they are the same for all a bodies, 64 -65?? Any ideas where to look? Could I just use generic runner in the channel? If so what size?
Old Mar 17, 2017 | 11:53 AM
It's called "channel weatherstripping" and it's generic. Steele Rubber, Restoration Specialties, etc, etc.
Old Mar 17, 2017 | 02:01 PM
Thx Joe, any idea what the size is?
Old Mar 17, 2017 | 02:03 PM
Unfortunately not off-hand (which is why I didn't answer that part of the question ).
When I got the channel weatherstrip for my 62 wagon, I brought the old one and matched it up.
Old Mar 17, 2017 | 04:32 PM
That's a good idea
"(which is why I didn't answer that part of the question )." Duh, ha ha, what happens when you type without thinking.
Old Mar 19, 2017 | 07:17 AM
442Harv's Avatar
I think, the company that makes them,makes two types. I think the info in their catalog, says something like this. One type is not quite like the original, and the other one to match the original, and it also costs more money.
Old Mar 19, 2017 | 07:22 AM
You may be thinking of the outer beltline fuzzies, that come with the flat stainless bead or the correct round one. The OP is asking about the U-shaped flocked runner that goes in the metal window channel inside the door. There are several styles and sizes, which is why I brought my old ones to match up.
Old Mar 20, 2017 | 06:53 PM
I pulled out the channel and it appears that it is lined with a fabric covered rubber that is glued into the channel. Steele Rubber calls it rubber backed mohair. Guess I'll see if they a dealer in Canada or ship here.
Any ideas how to remove the old stuff
Old Jul 10, 2017 | 10:44 PM
gmiles's Avatar
Molehair....That is the fabric used in the window guide channel and it keeps the glass from rattling in the door when the window is down. I re-did all the window guide channels in my 63 Cutlass. I bought a roll of generic molehair from an online vendor (google is your friend) and went to town. Made a huge difference in how the windows rolled up and down. They all work like new.
I think anything wider than 2" should be good to go. I used rubber cement and weatherstrip adhesive when I ran out of the cement. Use a paint stick to push the molehair in to the channel. Glue the edge down and use a razor to trim to size. Average cost was about $5 per foot.
http://www.rubbertherightway.com/win...54092-prd1.htm
http://www.steelerubber.com/run-chan...ner-70-2863-58
Old Jul 20, 2017 | 08:28 PM
That's what I ended up doing, gmile. The most time consuming thing is cleaning out the old molehair. A heat gun helps.
oldsmobiledave
Jun 23, 2015 07:13 PM
1970supremevert
Dec 9, 2013 09:54 PM
lunaboy
Dec 8, 2013 11:10 AM
stevengerard
Feb 17, 2012 06:44 AM
seansw-31
Oct 23, 2009 07:57 PM
