Will a modern 4x10 fit the dash of a 1970 Cutlass S?
Old Apr 7, 2016 | 02:43 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Doing body work right now and I am buying an upgraded cassette deck with 100 Watt of output. I can probably make the other one fit in the back, no rear speaker right now.
Old Apr 7, 2016 | 07:03 PM
VC455's Avatar
Barely Registered
4 x 10 is the correct size. However the resistance of the new speakers is 4 ohms, not 8 ohms the factory used. This only matters if you are using the original radio, which has the output transistor's collector biased for 8 ohms. The 4 ohm will work without damaging the radio, but rebiasing is required if you want good sound.
Be sure to use a quality speaker and actually measure the resistance if you have ANY doubt. Bargain speakers in this size often are very low resistance (below 1.3 ohms) which will damage the original radio.
Old Apr 7, 2016 | 08:09 PM
Aftermarket stereo. Just wondering how deep the factory bracket is for the front speaker? I know aftermarket 6x9's fit like **** in the back brackets of my G Body.
L69 equipped
Mar 19, 2017 12:31 PM
Alocatelli
Aug 4, 2016 05:55 AM
skryla
Oct 13, 2011 04:25 AM
squirell
Nov 8, 2009 04:38 PM
