What kind of bulb socket is used to hold the instrument bulbs on a 69 Cutlass conv.
Old Feb 4, 2015 | 01:59 PM
craftsmen22's Avatar
Cutlass driver in Germany
Hi,
on my Cutlass 69 conv. I miss one socket for the instrument lamps? Where can I get one? Any help on this is greatly appreciated.
And I am switching back to regular lights after installing LEDs in the instrument, because the LEDs didn't do a great job. Some quit work and to control the brightness via dimmer is not working that well, either. So would the lamp #168 work on all dashboard lights or is it wider to use different lamps?
Thank you,
Tom
Old Feb 4, 2015 | 02:07 PM
don71's Avatar
same but different
Yes the 168 is fine.
194 is also good. Both is ok in the instrument panel.
I don't know where you may find them in Germany.
Old Feb 4, 2015 | 02:09 PM
Hi Don,
no problem about the lamps, the socket is a bit harder here, might to do a internet search. But what socket should I search for.
Tom
Old Feb 4, 2015 | 02:42 PM
don71's Avatar
same but different
Ah, the socket. You place the bulb into the socket, then screw into the instrument panel, correct?
That might be a used part only, not available new. I don't know for sure.
I probably have one or two of those as many of us do.
Let us know .
Old Feb 4, 2015 | 03:16 PM
RandyS's Avatar
eBay is your friend.......http://www.ebay.com/itm/6pcs-Led-ins...a54190&vxp=mtr
Old Feb 4, 2015 | 06:42 PM
White_Knuckles's Avatar
^^ Nice find. The socket advertisement says "LED" but will accept a conventional incandescent bulb.
LED's do not dim down by reducing voltage to them rolling your dimmer ****. They require a "pulse circuit" device added to cycle them on/off rapidly giving the illusion they are dimming as the pulse gap widens.
Cheers
therobski
Aug 22, 2015 05:14 AM
GEARMAN69
Sep 12, 2014 08:50 AM
68442S
Apr 10, 2014 07:20 AM
ELECMAN
Mar 5, 2012 08:21 AM
auto_editor
Jul 10, 2011 11:20 AM
