weather stripping
It's a reinforcement wire for the weather strip. The new strip is glued in, I use the black weather strip cement, comes in a tube by 3M. It's a contact type cement that you put a thin coat on both the weather strip and in the roof rail channel, let it skin over and then bond the strip to the channel.
Go by a parts store specializing in paint & body supplies and get a spray can of 3M weatherstrip release agent, and a can of wax and grease remover. Then go by Harbor Freight and get a set of plastic scrapers like these, Pittsburgh Tools item#95832,
$10.99.
The release agent and scrapers will get the remaining old rubber and adhesive out of the channels and the wax remover will clean the surface so new adhesive and weatherstip will stick. You can also use the scrapers to push the new weatherstrip into its retaining channel. Doesn't hurt to test fit the stuff first without any adhesive.
Good luck!
$10.99.
Good luck!
