weather stripping
Old Jun 2, 2015 | 11:42 AM
mitchy's Avatar
weather stripping
I need to do the weather stripping on my car. I've already bought it i'm just not sure how to how to install the new stuff.
Old Jun 2, 2015 | 11:48 AM
Oldsmaniac's Avatar
Please be more specific as there are a number of different ones used and attach differently.
Old Jun 2, 2015 | 12:24 PM
^^^ x2.
Doors?
Roof rail?
Deck lid?
some have clips and holes in the sheet metal to accept the clips, and some have to be glued in.
Old Jun 2, 2015 | 12:40 PM
mitchy's Avatar
I started to remove some of it and hit a Little wire, And i'm not sure what it is and if ill need it, and i'm doing the roof rails and deck lid.
Old Jun 2, 2015 | 01:03 PM
Oldsmaniac's Avatar
Appears to be roof rail. This wire is embedded in the rubber. Remove it and the rest of the rubber there...
Old Jun 2, 2015 | 02:15 PM
It's a reinforcement wire for the weather strip. The new strip is glued in, I use the black weather strip cement, comes in a tube by 3M. It's a contact type cement that you put a thin coat on both the weather strip and in the roof rail channel, let it skin over and then bond the strip to the channel.
Old Jun 2, 2015 | 02:44 PM
mitchy's Avatar
Yeah I bought that stuff by 3M with the weather stripping from OPGI.
Old Jun 3, 2015 | 08:54 AM
rocketraider's Avatar
Oldsdruid
Go by a parts store specializing in paint & body supplies and get a spray can of 3M weatherstrip release agent, and a can of wax and grease remover. Then go by Harbor Freight and get a set of plastic scrapers like these, Pittsburgh Tools item#95832,
$10.99.
The release agent and scrapers will get the remaining old rubber and adhesive out of the channels and the wax remover will clean the surface so new adhesive and weatherstip will stick. You can also use the scrapers to push the new weatherstrip into its retaining channel. Doesn't hurt to test fit the stuff first without any adhesive.
Good luck!
Old Jun 3, 2015 | 07:10 PM
Lady72nRob71's Avatar
In lieu of the tools above, popsicle sticks cut with a chisel end and pieces cut from a scrap CD make good scrapers. They will be easy on the paint.
Old Jun 4, 2015 | 09:19 AM
Oldsdruid
Trouble with that is if I have popsicle sticks it means I'm eating popsicles, and I know I need to leave them alone! Whereas I won't try to eat the HF plastic scrapers...
brent
Oct 3, 2011 07:47 AM
roomer
Sep 13, 2011 05:14 AM
toms vista
Vista Cruiser & Wagons
Aug 27, 2010 09:07 AM
KRICHEN922
Body work
Mar 27, 2010 11:07 AM
yzzerdd
Mar 8, 2010 05:11 AM
