W31
The W-31 option was a high performance (small-block 350)factory drag car basically. In 68-69, it had the under bumper scoops and tubes up to the air cleaner like a W-30 442. In 1970, it was standard with the OAI hood and air cleaner assembly. It was rated at 325 HP but had much more. It had a factory balanced bottom end with large valve heads to handle a 308 duration cam. In 1970, it also had a W-31 specific aluminum intake! They all had a specifically built carb, and a balancer larger than any other Olds and also specific to the W-31! All of them came with the 4 core radiator for heavy duty cooling. The standard rear was a 3.90 posi. and all came with boxed rear cotrol arms and rear sway bar.(F-41) None of them ever had A/C regardless of what some say!! In 68 there were only 4 speeds, but auto. or standard available in 69-70. You need matching paperwork from the car that proves it is a W-31 or it is just a Cutlass with emblems installed on it!
youre probably talking about the green one on ebay right now.
it was for sale last year in tennessee for 12K,i believe it sold for 10K.
i do know of a documented 70 w31 without the original engine selling for 23k,but it wasnt green.
Um, not quite. The '68 W-31 had three manual transmissions available: the close ratio M-21, the wide ratio M-20, and the M-14 Heavy Duty 3-speed. 4.33s were standard with the M-21 and 3.91s with the other two. I know of a '68 M-14 W-31.
Be careful now I ordered my 1970 W-31 with a 3.42 gear and it certainly is not a wimp!!!!!!!!!! Actually one of 116 built as I ordered a Cutlass "S" post coup....W-31, wide ratio 4 speed, vinyl top bucket seats console delete...
Cool Olds, Bob. Still have it? Technically, the console was an option, so no console was not a delete. Regarding other questions asked elsewhere, is there a Z prefix to the trim code? And did it have option Y68?
