W31
Old Jan 5, 2009 | 11:42 PM
WEBBISH's Avatar
W31
What is the W31 option mean? The guy wants 18,500 with out the original engine it has a 350 is that the right engine for a w31
Old Jan 6, 2009 | 04:40 AM
Jokers69's Avatar
Senior Moment
This may help.. thanks to our friends at Fusiks..
www.fusick.com/w31.htm
Old Jan 6, 2009 | 12:40 PM
Eric Anderson's Avatar
As with the w-30's it will aslo need to be a Lansing built car and you need paperwork for proof. IMHO $18,500 is high for one w/o the origional engine.
Old Jan 6, 2009 | 01:17 PM
Considering that it is the engine that makes it unique...
Old Jan 7, 2009 | 06:36 PM
orange442's Avatar
The W-31 option was a high performance (small-block 350)factory drag car basically. In 68-69, it had the under bumper scoops and tubes up to the air cleaner like a W-30 442. In 1970, it was standard with the OAI hood and air cleaner assembly. It was rated at 325 HP but had much more. It had a factory balanced bottom end with large valve heads to handle a 308 duration cam. In 1970, it also had a W-31 specific aluminum intake! They all had a specifically built carb, and a balancer larger than any other Olds and also specific to the W-31! All of them came with the 4 core radiator for heavy duty cooling. The standard rear was a 3.90 posi. and all came with boxed rear cotrol arms and rear sway bar.(F-41) None of them ever had A/C regardless of what some say!! In 68 there were only 4 speeds, but auto. or standard available in 69-70. You need matching paperwork from the car that proves it is a W-31 or it is just a Cutlass with emblems installed on it!
Old Jan 7, 2009 | 09:55 PM
70Post's Avatar
Correction: 3 core OR 4 core radiator depending on rear gear.
Old Jan 8, 2009 | 05:49 PM
orange442's Avatar
Thank you Patton, forgot about that! But you know only wimps got the 3.42 rear, so they do not count!!
Old Feb 2, 2009 | 07:31 AM
agtw31's Avatar
youre probably talking about the green one on ebay right now.
it was for sale last year in tennessee for 12K,i believe it sold for 10K.
i do know of a documented 70 w31 without the original engine selling for 23k,but it wasnt green.
Old Feb 2, 2009 | 07:14 PM
harleyrules's Avatar
My red W31 without original engine sold several years ago for 22K but I did have documentation to prove real W31...
Old Feb 3, 2009 | 06:38 PM
wmachine's Avatar
Trying to remember member
Um, not quite. The '68 W-31 had three manual transmissions available: the close ratio M-21, the wide ratio M-20, and the M-14 Heavy Duty 3-speed. 4.33s were standard with the M-21 and 3.91s with the other two. I know of a '68 M-14 W-31.
Old Mar 1, 2009 | 05:25 AM
Bobsw32's Avatar
BobsW32
Be careful now I ordered my 1970 W-31 with a 3.42 gear and it certainly is not a wimp!!!!!!!!!! Actually one of 116 built as I ordered a Cutlass "S" post coup....W-31, wide ratio 4 speed, vinyl top bucket seats console delete...
Old Mar 1, 2009 | 06:41 AM
wmachine's Avatar
Cool Olds, Bob. Still have it? Technically, the console was an option, so no console was not a delete. Regarding other questions asked elsewhere, is there a Z prefix to the trim code? And did it have option Y68?
Old Mar 1, 2009 | 05:58 PM
Bobsw32's Avatar
BobsW32
I owned it for 35 years and it was taking up space in the garage so I found it a new home... It is close by,,,,,I have visitation rights and the first right of refusal if he would sell it.....It is in a good home.
Old Mar 1, 2009 | 07:13 PM
wmachine's Avatar
Would you be able to find out if there is a Z prefix to the trim code? And did it have option Y68?
Old Mar 2, 2009 | 07:35 PM
Bobsw32's Avatar
BobsW32
Sure can
I'll call joe tomorrow and ask him!!!!!!
Bob
Old Mar 4, 2009 | 10:24 AM
Bobsw32's Avatar
BobsW32
Joe
Looked last night and NO "Z" on the trim tag
and not Y68 code
what is Y68 anyway
Bob
Old Mar 4, 2009 | 11:06 AM
68Tom's Avatar
Anyone see the article in the new Mucsle Car Enthusiast on the '70 W-31 with the aluminum prototype block? Nice car, but the pics of it are kind of crappy. Owner of Inline Tube owns it.
Old Mar 4, 2009 | 11:11 AM
Bobsw32's Avatar
BobsW32
They had the car at detroit last year.....
Talk about a NICE CAR one up aluminum block.....
YAH HOOOOOO they car they should have built!!!!!!!!!!!!!!!!!!!!!!!
mono-plane
Aug 28, 2021 08:41 PM
agtw31
Sep 20, 2008 06:20 AM
<K.Adcox>
Oct 12, 2006 07:15 AM
Surfrat67
May 14, 2006 03:42 PM
