Trunk Trim Piece for '68 Cutlass- need length measured
Old Sep 4, 2013 | 09:14 AM
shamusj's Avatar
Hi Guys,
I'm going to look at a trunk trim piece later this week and need to make sure I'm getting the right part. I'm talking about the long thin OLDSMOBILE script that hangs on the back lip of the trunk- just above the bumper line.
I have a '68 442 Convertible- I know the convertible trunk trim is different than the hard top. Many people think the parts are interchangeable....I dont want to get stuffed with the wrong piece.
Any chance someone could measure the length of the hardtop or convertible piece- this will tell me if I'm looking at the right part. Just need the horizontal length right to left.
Thanks very much.
Mike
Old Sep 4, 2013 | 09:54 AM
Octania's Avatar
Look at the backside of the trim.
The Longer one has a line where it is to be cut to make the shorter one.
If the line is not there, it already is the shorter one.
However, my feeble memory fails to tel me which is the longer type, therefore which you need.
If you get length #'s I will add them to the PN database for occasions like this.
Old Sep 4, 2013 | 09:57 AM
scr8p's Avatar
convertible is shorter.
Old Sep 4, 2013 | 10:14 AM
olds1968's Avatar
member
I dont have a tape measure but i looked at mine and did notice the notch on each end of the trim this is on a coupe.
Old Sep 4, 2013 | 01:29 PM
sammy's Avatar
Sammy70 455 Supreme
looks to be 60 inches to the line for a convertible. Trim pictured is from a 68 442 sports coupe...
Old Sep 4, 2013 | 04:19 PM
shamusj's Avatar
Wow- great information and quick turn around. Thanks to all.
So....is it correct to assume I could use a hardtop trim piece and cut it to fit? Wonder if the studs would be placed correctly?
If so- this is news to me...I've been thinking the parts were completely different for the past 10 years.
Thanks again.
Old Sep 4, 2013 | 05:04 PM
starfire's Avatar
Just measured the one on my 'vert. It is 60" long.
Stud distances (not exact, but close) from left 1-3/8" 10", 19", 28", 32", 41", 50", 58-5/8".
Old Sep 4, 2013 | 05:23 PM
allyolds68's Avatar
I believe they cut the piece and then chromed it so the ends won't be correctly chromed if you cut a hardtop one. I would imagine the studs are the same but it's been years since I had two of them together to see
Old Sep 4, 2013 | 05:24 PM
sammy's Avatar
Sammy70 455 Supreme
Roughly the same stud distances on the longer coupe trunk trim...
Old Sep 4, 2013 | 07:32 PM
starfire's Avatar
Makes sense if it's the exact same piece, but with ends not cut off.
Old Sep 6, 2013 | 07:06 AM
shamusj's Avatar
Went to look at one locally- all studs busted off and bent.....no thanks.
Anybody have one of these they want to sell? Looking for good to excellent condition.
Thanks again for all the help.
kncklhd1
Feb 16, 2014 03:24 AM
Del70
Jun 22, 2012 03:41 AM
joepenoso
Dec 26, 2011 05:37 AM
carmax
May 9, 2011 10:53 AM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
