transmission identification 68 cutlass
Old Nov 8, 2024 | 04:29 PM
beehall's Avatar
How do I determine which transmission is in my 350 4bbl cutlass s?
Old Nov 8, 2024 | 05:15 PM
69CSHC's Avatar
Assuming its an automatic, this may help. A chart to identify and confirm oil pan shape.
From post #6 of the following thread. https://classicoldsmobile.com/forums...n-swap-127939/
Old Nov 8, 2024 | 05:23 PM
I thought the automatic Cutlii had a TH350?
Old Nov 8, 2024 | 05:26 PM
69CSHC's Avatar
Jetaway in 1968. TH350 didn't exist yet. Unless someone swapped it into Beehalls car.
Old Nov 9, 2024 | 05:09 AM
^^^THIS! The standard and ONLY automatic trans that was available in the 1968 Cutlass was the ST300 (Jetaway) two speed. This is not a Powerglide.
Old Nov 9, 2024 | 08:34 AM
So, for starters, drive it and see if it shifts once or twice.
Old Nov 9, 2024 | 07:43 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Look at the shift indicator on either the speedo or console. It will indicate two forward positions, drive and low. As stated it should be a jetaway if original to the car.
If it blows up replace it with a BOP TH350.
Service it and change the fluid at least two to three times in a short period to get fresh fluid throughout.
Old Nov 9, 2024 | 10:15 PM
In most of the Jetaway to TH350 swaps I've seen (including the two I did), nobody bothered to change the shifter quadrant.
Crazy68Cutlass
Jul 2, 2021 10:46 AM
blakes7
Sep 27, 2020 03:29 PM
RROLDSX
Nov 22, 2013 09:44 AM
66luvr
Aug 9, 2012 01:48 PM
yeahbuddy
Jun 29, 2010 09:48 AM
