Steering wheel adjustment
Old Nov 3, 2024 | 01:59 PM
79cut's Avatar
Ok got this 1979 cutlass not long ago
the steering wheel I wish could be shorter torwards front of car. Looking around today I noticed I might just do that. I’m thinking it’s telescopic
it’s got a lever type thing
I push it down. Nothing happens
anyone know how these work ?
I don’t think it’s tilt steering
Old Nov 3, 2024 | 06:18 PM
The lever is to allow you to turn the key to the LOCK position. You're supposed to hold that lever down while turning the key. It is not a telescoping column.
Old Nov 4, 2024 | 04:17 AM
BlueCalais79's Avatar
If it were a tilt column you would have a (screw in) lever on the left side of the column next to the directional signal lever.
Old Nov 4, 2024 | 04:22 AM
79cut's Avatar
yup. I was hoping it would be telescopic lol
oh well
one day I will change it for something smaller
or try a smaller steering wheel
Old Nov 4, 2024 | 01:55 PM
Rocketguy's Avatar
It's a bit hard to tell from the pics but that column looks awful long coming out of the instrument panel; are you sure that is the correct one for the car?
Old Nov 4, 2024 | 02:56 PM
79cut's Avatar
it’s about 10 inches long
mostly likely not the one for this car
Old Nov 4, 2024 | 07:12 PM
More to the point, that vintage Olds did not use the locking lever to turn the key to LOCK. That column likely came out of an F-body, probably to replace the original column-shift column for a floor shift.
Old Nov 5, 2024 | 05:09 AM
79cut's Avatar
Probably that’s what it is
I would like to install a telescopic one if I can at some point
Old Nov 5, 2024 | 06:01 PM
GM never offered a telescoping column for the A or G-body cars. Any full size column will likely still be too long.
Old Nov 5, 2024 | 06:10 PM
79cut's Avatar
really wow.
Old Nov 6, 2024 | 04:36 AM
2x on Joe P's note, I would suggest finding a correct tilt column, I have one in all 3 of my 79's and it's a great assist to a more comfortable ride. My black/silver Brougham and my H/O already had one, and I installed one in my blue Calais. It's a bit of a chore but it's entirely do-able.
Old Nov 6, 2024 | 05:29 AM
79cut's Avatar
I don’t think I need a tilt column
mine is already at its max height anyway
I’ll probably look at a smaller steering wheel as mine is 15 inch
Cosmic Charlie
Jan 30, 2024 08:04 PM
russell-t
Nov 29, 2023 08:37 AM
pvossn66
Oct 16, 2023 03:39 PM
LeroyGreat
Oct 4, 2023 07:27 PM
tnswt
Dec 8, 2021 03:12 PM
