Power steering box lubricants
Old September 27th, 2022, 11:47 AM
ilikeolds's Avatar
Whitch oil is used in the Oldsmobile Cutlass 1966 power steering box?
Viscosity, etc..?
ilikeolds is offline
Old September 27th, 2022, 12:14 PM
Oldsdruid
rocketraider's Avatar
Factory recommendation was Type A automatic transmission fluid. Modern equivalent is Dexron III ATF.
You can also use any general use power steering fluid.
rocketraider is offline
Old September 27th, 2022, 12:48 PM
ilikeolds's Avatar
Thumbs up power steering gear oil
Thanks a lot from Luxembourg
Old October 6th, 2022, 02:43 PM
67' OLDS
aslockcuff's Avatar
How much fluid should be in the pump?
aslockcuff is offline
Old October 6th, 2022, 03:18 PM
This much
joe_padavano is offline
Old October 7th, 2022, 04:11 AM
ilikeolds's Avatar
After bleeding, less than 2 quarts ( Olds 330 CC w/power steering)
Old October 7th, 2022, 03:17 PM
72Cutlass S
gs72's Avatar
This much
gs72 is offline
Old October 7th, 2022, 07:40 PM
RandyS's Avatar
The 1966 Cutlass PS Pump does not have that kind of cap. It's one of the 1/2 turn style with no dipstick attached. About half way up the filler neck works.
RandyS is offline
TommyTheCat
June 29th, 2020 11:02 AM
teamwieland
Suspension & Handling
23
June 11th, 2019 10:31 AM
FTolliver
April 15th, 2018 03:59 PM
anthonyP
November 20th, 2014 09:50 AM
agtw31
15
June 14th, 2010 06:01 AM
Quick Reply: Power steering box lubricants
