new postive battery cable 72 cutlass 350
Old Jan 17, 2010 | 08:17 PM
mmcilroy's Avatar
Death by a thousand cuts, after rebuilding the ENTIRE front end, and rebuilding the motor. Cleaning and restoring the firewall and all the components mounted to it. Cleaning every nut and bolt. I have now come to the conclusion this evening that I should replace the positive battery cable. After some basic google searching I can't seem to find one! Any help in locating the correct cable with the heat shields included would be appreciated.
It just one thing after another.
Old Jan 17, 2010 | 08:42 PM
70 cutlass s's Avatar
The heat shield if your talking about black plastic covering the cable. You can buy that at any auto parts store. The battery cable I would think Year One, Paddock, The Parts Place would sell them.
Old Jan 18, 2010 | 01:55 AM
oldsonharmont's Avatar
Fusick has the original style ones if you want to go that way and spend about $50 per cable. I went to a local battery distributor and had one custom made with crimped on terminals and shrink wrap. (only cost $7.50)
Old Jan 18, 2010 | 03:40 AM
Bluevista's Avatar
Registered
That's fabric wire loam on those, never seen that on those cables there?
It has to go on before it's assembled, that's not plastic convalute tubing.
Unless it's asbestos fabric loam it's more to prevent abrasion than anything else.
That looks like a top post cable?
Didn't the 72's use side post batteries?
Old Jan 18, 2010 | 04:10 AM
cutlassgal's Avatar
Cutlass Lover
My battery has side posts
Old Jan 18, 2010 | 05:16 AM
Lady72nRob71's Avatar
1972 was the first year for Cutlass side terminals.
The picture resembles a side post term in very bad shape, missing the screw...
Old Jan 18, 2010 | 06:17 AM
Bluevista's Avatar
Registered
That is a side post, my bad.
Did the originals have that fabric covering on the battery end?
Major faux pas if the repos are supposed to and don't, do they?
Maybe they did that because that cable and wire can rub the side of the battery on side posts?
A lot of older cars had the fabric anyplace where rubbing or pinching could cut or damage the wire.
Old Jan 18, 2010 | 09:36 AM
mmcilroy's Avatar
Thanks for all the replies. It is a 72 side post cable. That destroyed connector in the picture is what was attached to the starter. The end pictured was what passed through the insulator tube and connected to the starter and, crap, would need to refer back to some other pictures I have as to where the smaller gauge wire went to. Maybe it was the solenoid? Looked at some of the after market suppliers recommended in the earlier reply and their pictures were not very clear as to how their cable assembly would be constructed. I guess I'll have to call them and see if they can provide more details like if they include the insulator on the cable.
On a side note, This forum is amazing. I have been reading everyone's restoration stories and enjoying all the pictures. I'll have to post some of mine. Not your classic frame off, and unfortunately after I'm done the car will look exactly the same going down the road but it should drive better than new and look great under the hood. Does anyone sell a clear plastic hood? lol
Again thanks for the replies, hopefully after all the things I'm learning about rebuilding the front end and engine compartment will allow me to contribute some help instead of being the needy one!
Old Jan 18, 2010 | 03:26 PM
Chumley's Avatar
I've always got all of my electrical stuff through M&H electrical. They fabricate exact replicas. I got a new engine harness and positive battery cable from them, and no problem. I have never seen the insulator tube you refer to reproduced by anyone. They usually go for around $50 and up on ebay, depending on condition. Go to this website for info:
www.wiringharness.com Chumley
Old Jan 18, 2010 | 04:57 PM
mmcilroy's Avatar
Just so everyone doesn't think I'm crazy here's a picture of the positive battery cable connected to the starter before everything was torn down. What ever the heat shield was for it sure looks like a good idea to find something to replace it due to its close proximity to the block. Or maybe a previous owner routed it the wrong way. No body else has this cloth looking sheath over the starter end of their cable?
Old Jan 18, 2010 | 08:06 PM
OLD SKL 69's Avatar
GM Enthusiast
My 71 does not have that covering on it. It is an unmolested car with 42k org miles. Someone else would have to chime in here with a 72 for comparison.
Old Jan 19, 2010 | 04:54 AM
My442's Avatar
M&H is the best.
Old Mar 6, 2013 | 05:49 AM
ddd777's Avatar
might that be this:
http://www.fusickautomotiveproducts....?number=BCT684
"1968-74 V8 Battery Cable Tubes: Necessary part for all detailed restorations of Cutlass, 442, H/O models with V8 engines. Positive battery cable is routed through tube at rear of engine for heat protection. Made of brown heat resistant material and mounting bracket is included. Automatic transmission cars used 5 1/8” long tubes while manual transmission cars used 7 5/16” long tubes."
Old Mar 24, 2013 | 06:28 PM
classicmuscle442's Avatar
ddd777 thats the orginal insulator, if you have the bracket you could use a shipping tube, its the same material, just cut to lenght, not for show but will work
therobski
Aug 9, 2015 02:18 PM
wr1970
Sep 30, 2014 12:46 PM
Texas442
Mar 28, 2013 07:13 PM
BigPapa
Feb 24, 2013 09:46 AM
w-30dreamin
Jan 9, 2010 03:19 PM
