New Owner Question
Old Sep 3, 2010 | 10:32 AM
Bottoms's Avatar
New Owner Question
I noticed when I was getting my Dad's Cutlass out of the garage that it did not have a steering lock in park and that I was able to shift out of park without the key being turned at all. Is this normal on a 67 Cutlass?
Old Sep 3, 2010 | 10:48 AM
Yep, The first year for steering locks was 69
And Welcome aboard
How bout some pics of your car?
Old Sep 5, 2010 | 10:17 AM
Chumley's Avatar
I have a '72 Chevy pickup that will shift without the key. Ignition is on the dash. I guess this was only for column mounted ignition switches.
Old Sep 5, 2010 | 05:14 PM
It's the other way around. The ignition switch was moved to the column in order to facilitate the lock mechanism (although newer cars use cables or solenoids to allow the key to be just about anywhere these days). More to the point, the law in 1969 applied to cars only. The locking requirement for trucks was later, and was phased in by GVW.
Old Sep 5, 2010 | 07:03 PM
Bottoms's Avatar
ahh haa. thanks
Old Sep 7, 2010 | 05:39 PM
Chumley's Avatar
That's what I meant Joe, I've never seen a lock on a dash ignition.
Chumley
Old Sep 21, 2010 | 07:10 AM
Moses's Avatar
I had a '66 Bel Air Wagon back in '83 (?) that I could remove the ignition key while car was still running, that was cool! Don't know if some early cars still do that or if it depends on the key.
Old Sep 21, 2010 | 07:16 AM
VikingBlue's Avatar
I can take the keys out of my 71 442 while it's running too...has been that way ever since I got the car in '89....but I thought it was because the keys are worn.
Old Sep 21, 2010 | 07:27 AM
It is because the keys (and more likely the lock cylinder) is worn. When the gov't mandated the steering column lock for the 1969 model year, they also specifically mandated that the key could only be removed in the LOCK position. On earlier cars it was possible to remove the key with the ignition switch in the RUN position, but the feds mandated that not be possible on later cars.
Old Sep 21, 2010 | 07:58 AM
Moses's Avatar
Cool! Thanks guys.
blunosr68
Apr 23, 2019 06:15 PM
lmetcalf
May 31, 2012 06:23 PM
jrblanke
Jan 27, 2008 10:12 AM
redrumloa
Mar 10, 2007 06:45 PM
Grizld700
Alero
Dec 14, 2006 07:57 AM
